electrical problem: car has no power with new battery.
so i got this civic and it didn't start so i bought a new battery.
the car has no electrical power. no interior lights, none of power door locks works.
the car doesn't start. i checked the fuses it look fine. what's wrong? help pls thanks.
ALL fuses? under dash and hood? are the pos and neg cables even connected to anything after they are connected to the battery? lol thats odd...
edit: clean the pos and neg connections with a steel brush. get it at autozone, or use some sand paper. try doing it to both......and the other end of the neg wire too....that goes from the battery to the body. trying cleaning both sides?
checked both under dash fuse box as well as the one under hood (near the battery).
neg is ground on car.
pos is connected to fuse box under hood then goes out to the starter side.
any more help appreciated. thanks.
Check the main fuse in your fuse box by your battery. Check the positive terminal wire where it enters the fuse box and look closely at the fuse attached to it, if there was a spark hooking the battery up or trying to jump it with the cables reversed, that main fuse would have blown and the car would have no electrical power.
I ran into a problem like this before. Check the wire that go from the battery to the under hood fuse box. Check it for continuity. In my situation, the wire melted or corroded or something, so no power was getting to the car. The car was completely dead(absolutely nothing electrical worked).
props to 00Red_SiR and 96BlackHB
the problem was that the pos wires going in & out were crossed in the fuse box under hood so no electrical power whatsoever. after i checked all fuses & switched
the 2 wires around, the car has power and the engine starts right up.
wow, you guys are helpful.
Hi I don't know if you're still active in this forum but my car is giving me that same problem, all my fuses are good but no power at all no ignition or anything and the battery is full when I connect the terminals it doesn't spark so I don't know what's cause that please help me out
GPC91
May 7, 2013 09:06 PM
c for sea
21
Aug 12, 2005 06:38 PM
