should I upgrade to B18b crank?
Old Nov 9, 2004 | 11:14 PM
cygnusX1's Avatar
Default should I upgrade to B18b crank?
I have the GSR crank already... would it be worth it to get an LS crank? Is the 1.3 mm longer stroke really noticeable? If I were to get the LS crank, what would I have to do to it to make it handle 9000 revs? just balance it to that RPM? (I know about the rods, bolts, and valvetrain having to be able to handle the revs.... I'm just interested in what I have to do to the LS crank to make it smooth at those rpms)
Old Nov 9, 2004 | 11:16 PM
cygnusX1's Avatar
Default Re: should I upgrade to B18b crank? (cygnusX1)
sorry... 1.8 mm longer stroke
Old Nov 10, 2004 | 06:51 AM
CompressionFed's Avatar
Get the crank balanced, and continue to use the GSR block brace. Remember to use LS rods, or aftermarket rods that are the correct length. Also, use upgraded rod bolts.
You should notice the car pulling a little harder...I think its a great upgrade.
Old Nov 10, 2004 | 07:25 AM
mmuller's Avatar
Mad Scientist
Default Re: should I upgrade to B18b crank? (CompressionFed)
yep, ls crank is a very worthy upgrade
Old Nov 10, 2004 | 01:02 PM
dome's Avatar
watch out for the oil squirters. i had to remove mine.
jordan2305
Dec 11, 2007 04:47 PM
CIVICSI12
Sep 19, 2006 06:02 PM
92sireg
Mar 10, 2005 05:25 AM
jdmsijdm
Dec 19, 2004 10:53 AM
sPaRk'iT
Aug 25, 2004 07:53 PM
