:::PLW wideband 02:::
Old Nov 9, 2004 | 07:52 PM
civicgsr19's Avatar
Default :::PLX wideband 02:::
EDITLX
I just got my plx m-300, and my question is where i should wire the power from? I have a vafc and i dont think i should get its power from there because ive read that these widebands are sensitive to the types of things, the same goes with the stereo.Im going to be using this instead of the stock narrowband o2 so can i use the power and ground from that? TIA .
-chris
Modified by civicgsr19 at 5:43 AM 11/10/2004
Old Nov 9, 2004 | 10:41 PM
civicgsr19's Avatar
Default Re: :::PLX wideband 02::: (civicgsr19)
Bump for the misspell!
Old Nov 10, 2004 | 06:00 PM
civicgsr19's Avatar
So no one can help eh?
Old Nov 10, 2004 | 07:50 PM
DefiantGSR's Avatar
http://hondata.com/plx.html
Old Nov 10, 2004 | 08:07 PM
DefiantGSR's Avatar
Default Re: :::PLX wideband 02::: (DefiantGSR)
"Connect the simulated narrowband signal (gray) wire from the M-Series controller to the O2 signal input wire. This is the same wire that would come from your stock narrowband 0-1V signal."
Old Nov 10, 2004 | 09:45 PM
b00sted93Hatch's Avatar
Wire it up to a relay and run it to the battery.
Old Nov 10, 2004 | 10:29 PM
civicgsr19's Avatar
Default Re: :::PLX wideband 02::: (b00sted93Hatch)
Thanks guys, i tried to get the directions off of the plx site but i don't have adobe acrobat to read the .pdf files. That hondata site is what i was looking for though, i will install this weekend, and ill let you know how it works.
thanks ,Chris
Old Nov 12, 2004 | 08:07 PM
1stGENGSR's Avatar
Please hit us up with an update after you get everything installed, I've heard of this 02 and controller before, but never any results on how well it works....
tecatown2091
13
Feb 3, 2013 08:11 AM
turbostd
Dec 4, 2008 04:03 PM
hksdrager
May 11, 2007 07:55 PM
Doodoo
Mar 25, 2003 04:48 AM
