Wiring a switched ground for VTEC control
Old Nov 9, 2004 | 07:33 PM
TimeRacer's Avatar
Default Wiring a switched ground for VTEC control
I understand that I need a 30a 4 pin relay to actuate the VTEC solenoid but does anyone know how to prevent the CEL because the VTEC solenoid line has to be cut to use the relay. I've considered using the VTM wire somehow in conjunction with the VTEC solenoid wire so it sees the correct voltage though not exactly sure how to do this... the second is just wiring the VTEC solenoid wire directly to ground with a resistor & diode inline though I'm not sure if this will work. Any insight would be appreciated!
Old Nov 9, 2004 | 07:49 PM
drdisco69's Avatar
Default Re: Wiring a switched ground for VTEC control (TimeRacer)
If you have a vtec ecu, what are you trying to accomplish?
Old Nov 9, 2004 | 08:14 PM
TimeRacer's Avatar
Default Re: Wiring a switched ground for VTEC control (drdisco69)
Using my EFI PMS's switched ground (RPM and load dependant) accessory port to activate a relay to control the VTEC engagement point. The problem with this is that the OEM ECU will see that the wire to the VTEC solenoid is cut and throw a CEL. I'm trying to figure out a way to prevent the ECU from throwing a CEL. I currently have a V-AFC installed to control the VTEC engagement point but having two piggybacks when I can have one.. I'll take the one.
JDM94HATCH
12
Nov 15, 2006 02:06 AM
05 S2K Stoner
Oct 28, 2004 06:40 AM
ball
Oct 29, 2002 05:50 AM
sharkcohen
Jul 20, 2002 06:29 PM
