How long do springs take to settle?
Old Nov 9, 2004 | 07:20 PM
Elemental's Avatar
Default How long do springs take to settle?
I installed h&r race springs on koni yellows 2 weeks ago and i still have 2 fingers worth of wheel gap. whats the deal? how long does it take for these fuggers to look good, like in the pictures you all post up?
<--------- sounds like ubernoob right now.
Old Nov 9, 2004 | 07:26 PM
simon98h22's Avatar
Default Re: How long do springs take to settle? (Kyoushu)
From what I've seen, they shold settle pretty quick. (as in hours .. MAYBE a day or 2)
How much were they suppose to lower ? What year Teg do you have ?
Old Nov 9, 2004 | 07:28 PM
Integrt's Avatar
Default Re: How long do springs take to settle? (simon98h22)
no it's usually a week or so for them to settle. my car settled .5 inches a week later
Old Nov 9, 2004 | 07:29 PM
Elemental's Avatar
ive got a 2k ls 2dr.
they are supposed to lower to veery little or no wheel gap, even tucking sometimes.
If it doesnt settle to the way it is supposed to, I am going to have to buy some gc coilovers.
Old Nov 9, 2004 | 07:30 PM
Elemental's Avatar
so any ideas why it doesnt have the no wheel gap look?
Old Nov 9, 2004 | 07:57 PM
dFreezy's Avatar
Default Re: (Kyoushu)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kyoushu &raquo;</TD></TR><TR><TD CLASS="quote">they are supposed to lower to veery little or no wheel gap, even tucking sometimes.</TD></TR></TABLE>
theyre not supposed to drop a specific height, thats why the description of them lists a range of heights they can be (between 1.75"-2.5" drop for the race springs), depending on your setup. i have about the same drop you do on the sport springs (~2"), so you landed almost in the middle of the range given.
Old Nov 9, 2004 | 08:03 PM
Elemental's Avatar
crap. it hurts me that i am going to have to sell my perfectly good springs because i fudged up.
Old Nov 9, 2004 | 08:05 PM
dFreezy's Avatar
personally, i think a two finger-width gap looks good and is very comfortable for daily driving (no scraping), but thats just me. someone will definitely buy them from you in the classifieds, just don't expect to get every last penny you spent on them back. good luck
Old Nov 10, 2004 | 08:37 AM
simon98h22's Avatar
Default Re: (dFreezy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dFreezy &raquo;</TD></TR><TR><TD CLASS="quote">personally, i think a two finger-width gap looks good and is very comfortable for daily driving (no scraping), but thats just me. someone will definitely buy them from you in the classifieds, just don't expect to get every last penny you spent on them back. good luck</TD></TR></TABLE>
Agreed
All cars drop diff ... this is why springs have a range. 2 finger I'd be happy with, excessive drops I'm not fond of. To each their own I guess
Old Nov 10, 2004 | 09:41 AM
.brian.'s Avatar
Default Re: (simon98h22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kyoushu &raquo;</TD></TR><TR><TD CLASS="quote">crap. it hurts me that i am going to have to sell my perfectly good springs because i fudged up. </TD></TR></TABLE>
Maybe not, I might be interested in a few weeks.
Old Nov 10, 2004 | 10:28 AM
Elemental's Avatar
if you are, hit me up.
Old Nov 10, 2004 | 10:51 AM
be.twenty's Avatar
u sure they're h&r race and not h&r sport... you might have the sport on there.
Old Nov 10, 2004 | 10:53 AM
purplegsr's Avatar
They should be close to done settling by now, most springs from Neuspeed/H&R/Eibach are preloaded so they won't drastically settle after you put them on. But you can expect a little change, but probably less than a finger.
Did you make sure that you are using the lowest perch on your Yellows?
I have a set of Intrax springs (just for the front) that should make it low in the front at least, if you are interested let me know.
Old Nov 10, 2004 | 11:36 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: (shogun-dc2)
I dunno what the deal w/ yours is, but here is my car the very next day after installing H&R Sport springs about 2.5 years ago:
Almost no gap, Race has gotta be lower.
*edit*
ahhh you're using Koni shocks? Make sure you installed the front spring perches correctly, like this:
...._____
_/______\_
NOT like this:
__________
..\______/
They can go on easily either way, and if you put them upside down the front will sit noticeably higher than if they are installed the correct way.
Old Nov 10, 2004 | 12:14 PM
FeatherWeight
Guest
Posts: n/a
Default Re: (PatrickGSR94)
for H&R race.. took me a few weeks for mine to settle, when I had those.
Old Nov 10, 2004 | 05:30 PM
RallyRedGT-V6's Avatar
Default Re: (FeatherWeight)
my sports ended up with less than a one finger gap..
Old Nov 11, 2004 | 05:16 AM
Elemental's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">I dunno what the deal w/ yours is, but here is my car the very next day after installing H&R Sport springs about 2.5 years ago:
*edit*
...._____
_/______\_
NOT like this:
__________
..\______/
They can go on easily either way, and if you put them upside down the front will sit noticeably higher than if they are installed the correct way.</TD></TR></TABLE>
that is about the wheel gap i have on the right wheel. on the left, I have noticeably less than that.
i dont understand what you meant by the diagram, tho... ??
Elemental's Avatar
you mean not install the springs upside down?
they are on the right way up.
the threads on the top of the shock are uneven, tho. Hmmm.
Old Nov 11, 2004 | 05:25 AM
Community Builder
You mean the amount of threads visible above the jam nuts? Either one side isn't tightened all the way, or you didn't install all the hardware on one side.
The diagram is a side (edge) view of the spring perch. If you look at the spring perch for the front shocks, the diagram should be clear. They will fit on the shock both right side up and upside down. If it's installed upside down, the car will sit probably 1/2 to 1" higher on that particular corner. But if they are installed upside down, it would be easier for the spring to slip off the perch, so you need to make sure they are installed correctly.
The lower right piece in this pic, it's sitting on the ground right-side up here:
It should be installed on the shock this way (pictured w/ my old H&R Sports):
Old Nov 11, 2004 | 10:15 AM
Elemental's Avatar
o damn! that might be it! when i took the assembly out the other day, it was almost slipped off. ill take it out again today and check on it.
thanks x 1000 for help man.
Old Nov 11, 2004 | 12:12 PM
Elemental's Avatar
yack! i just checked and that was it.
i feel disgusted with myself.
thanks a lot.
Old Nov 11, 2004 | 02:30 PM
1Tym's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kyoushu &raquo;</TD></TR><TR><TD CLASS="quote">yack! i just checked and that was it.
thanks a lot. </TD></TR></TABLE>
so how's the drop now?
Old Nov 11, 2004 | 07:20 PM
Elemental's Avatar
all i had time to do was check today (school then work). If i can borrow a digital camera, ill do a before and after. Ill probably do it tomorrow after school.
Old Nov 11, 2004 | 07:32 PM
m R g S r's Avatar
Where did you put the ratainers for the springs? There are 3 different grooves that they can go in.
Look at the pic, I think it's on the middle groove in the pic.
Old Nov 12, 2004 | 05:13 AM
Elemental's Avatar
i only saw one when i was installing mine...
