slipping clutch?
Old Nov 9, 2004 | 07:19 PM
esca's Avatar
Default slipping clutch?
while im driving.. and near almost every gear low rpms i hear a thunk thunk thunk thunk sound.. (clutch released) does this mean my clutch is going bad? and needs replacing?
what are the symptoms of a clutch going bad?
Thanks in advance
Old Nov 9, 2004 | 07:48 PM
Col. K0rn's Avatar
Default Re: slipping clutch? (esca)
A thunk thunk sound is definitely not good. Your post is twofold. I'll try to help as best I can.
Question One:
A sure way to tell if your clutch is bad is if you are in a higher gear than you should be, and you hear the engine tach up, but don't increase ground speed; like 5th gear at 20 MPH. If you hear the engine rev up, and you aren't gaining speed, the clutch is shot.
Question Two:
If the sound is consistent in its frequency, in every gear, I would lean toward something in the transmission/differential/planetaries.
Is the sound consistent at all speeds, based upon the engine RPM's? Try to give as much detail as possible.
Possibly a tire that has a tread separating? That makes a thunk thunk sound. Or is it a wop wop wop???
Old Nov 9, 2004 | 10:02 PM
esca's Avatar
Default Re: slipping clutch? (Col. K0rn)
kinda like a grinding.. usually in the higher gears.. from 2-3 k rpm
i always thought the clutch as like.. slipping a little.. its like how you hold a crayon at the top and drag it along the paper like how it skips
Old Nov 9, 2004 | 10:28 PM
eMpAtHy's Avatar
good to know my clutch isnt shot..my car is at like 800 rpm's and 20 mph in 5th gear..and i know if i let go..itll sound like im about to stall :X
Old Nov 9, 2004 | 10:38 PM
napalm_srv's Avatar
how high can u lift ur foot off the clutch b4 ur car stalls?....best way is to do what KOrn said in his first question. my car did that for a while, but i finally changed it..so niceeee
velisma
16
Jun 14, 2010 08:37 AM
nd8ch
Jan 29, 2004 09:52 AM
nd8ch
31
Jan 28, 2004 10:03 AM
sinfulDB1
May 5, 2003 09:26 AM
lliew
12
Jul 30, 2002 08:27 AM
