I have a quick question for you guys
Old Dec 24, 2001 | 07:43 PM
hooptie157's Avatar
Default I have a quick question for you guys
I took my car into VTEC when it was cold and it didn't go into VTEC until like 5 minutes later. Did I do any damage to my R?
Old Dec 24, 2001 | 07:44 PM
Ross's Avatar
25 Year Member
Community Builder
Community Influencer
Active Streak: 30 Days
Default Re: I have a quick question for you guys (hooptie157)
I'd say probably not? Ive done this once or twice and my car runs fine (when it's not crashing).
Old Dec 24, 2001 | 07:46 PM
TypeR 599's Avatar
just try not to do it. and next time, warn her up
Old Dec 24, 2001 | 07:47 PM
pleiades nutz's Avatar
The oil is not hot enough for the engine perform under those "stressfull" conditions of vtec so the computer doesn't allow it to untill its all warmed up. I'd say your ok just try not to do that too often.
Old Dec 24, 2001 | 10:50 PM
BlkITR #1404's Avatar
Default Re: I have a quick question for you guys (Fuzznuts)
Dont worry, i've done the same thing on my way to school. I wasn't paying attention and missed my normal 4grand shifts in the morning before warmed up and VTEC never kicked in and i looked and i was at like 6700rpm and nothing happened. Runs perfect now, so no damage done. Scared me though..........
Old Dec 24, 2001 | 10:55 PM
TypeR 599's Avatar
well, if the more vtec doesnt kick in b/c of engine not warmed up, then... we rev to redline on the primaries? hmm...that cant be good... I haven't done it before, but I don't want to find out personally with my own car. anyone have some clue?
[Modified by Fuzznuts, 4:59 AM 12/25/2001]
hm...can the primaries take it all the way? it would probably be making 140hp or less
Old Dec 25, 2001 | 12:00 AM
SoCal ITR's Avatar
Default Re: I have a quick question for you guys (type R 599)
I have that all the time, I've just come to the conclusion that VTEC doesn't kick in when it's cold. Usually only takes a couple of minutes until it works, although I have taken it to 7000+ on just the primaries, barely gets there though. Still works, so I'm not worried. If it were a problem, then Honda wouldn't let the car do it.
Edit: I think that's what I took it too. I could be wrong though.
[Modified by SoCal ITR, 5:44 PM 12/26/2001]
Old Dec 25, 2001 | 05:33 AM
TypeR0149's Avatar
Default Re: I have a quick question for you guys (SoCal ITR)
I do it all the time, i love those cold morrnigs where right out of the garage i redline it, it makes feel like i have my LS again, j/k
Old Dec 26, 2001 | 09:48 AM
Trey's Avatar
25 Year Member
Default Re: I have a quick question for you guys (Vegeta)
It's safe to do it. The ecu knows that the engine is cold and doesn't allow Vtec to work. It also lowers the redline so you can't damage the motor. Next time you do it watch the rpms when you hit the rev-limiter, it'll be around 6k instead of around 8k.
Vtec won't work if the engine is cold, the oil pressure (level) is low, the car is not going over 35mph and it's in limp mode (check engine light is on, certain codes only).
Old Dec 26, 2001 | 09:50 AM
Back in Black's Avatar
Rather OG
Default Re: I have a quick question for you guys (Ross)
You've made the cut again, my friend
Old Dec 26, 2001 | 09:52 AM
Lip's Avatar
Lip
Default Re: I have a quick question for you guys (Trey)
i remember dynoing my car at 190whp and then realizing i was doing this on my primary non vtec lobes at 9000rpms. things a loose wire will do
Old Dec 26, 2001 | 10:29 AM
GRM Scott's Avatar
25 Year Member
Default Re: I have a quick question for you guys (Lip)
Still, you should wait till the engine warms up before winding it out, the new M engines have a tach with lights that progressively raise the redline as the engine reaches it's operating temp. No sense in causing undue strain, use a little preventitive patience
Old Dec 26, 2001 | 12:55 PM
ZygSpeed's Avatar
Default Re: I have a quick question for you guys (Aleph)
A reminder for those of you running Mugen or some other "RACE ONLY" ECU, ... there are "usually" no "safeguards" like this!
That's also why there's no "check engine" light when running a test pipe.
Old Dec 26, 2001 | 04:47 PM
SoCal ITR's Avatar
Vtec won't work if the car is not going over 35mph
1st gear?
Old Dec 26, 2001 | 05:15 PM
B2FiNiTY's Avatar
1st gear?
Hahah. I was also gonna say something bout the 6k revlimit too.
x GotBoost x
Honda S2000
Mar 29, 2006 05:08 AM
Geeq
Nov 15, 2004 10:21 PM
Luserkid
Dec 28, 2002 09:53 PM
