safe to switch back to conventional oil from synthetic??
Old Nov 9, 2004 | 07:03 PM
danny98r's Avatar
Default safe to switch back to conventional oil from synthetic??
i am currently runing mobil 1 5w30 and im burning oil. i wanted to know if i can switch back to conventional oil to see if it stops. is there any problems if i switch back. i heard its bad for the motor, and once u go synthetic u should not go back
Old Nov 9, 2004 | 07:10 PM
B18OnTop's Avatar
Default Re: safe to switch back to conventional oil from synthetic?? (danny98r)
I wouldn’t. All Hondas burn some oil. How much oil are you burning? Maybe try running 10w 30
-Aaron
Old Nov 9, 2004 | 07:21 PM
Azcheron's Avatar
Default Re: safe to switch back to conventional oil from synthetic?? (B18OnTop)
def. not!
using full synthetic and then switching back to a non-synthetic can fug up a lot of your seals and **** really bad
90% of the time when people complain about synthetic oil being bad, it's because they switched from it to a non-synthetic and screwed up their seals
Old Nov 9, 2004 | 07:28 PM
Opie's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18OnTop &raquo;</TD></TR><TR><TD CLASS="quote"> All Hondas burn some oil. </TD></TR></TABLE>
Wrong.
I go a full 2,500 miles betwween changes without burning a drop. I may add a cap
full ocassionally if the level is a nail under the second dot, but, the next time I
check it's a nail above.
&lt;---- Uses 5w30 Castrol GTX Dyno
fangtl's Avatar
Default Re: safe to switch back to conventional oil from synthetic?? (Azcheron)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Azcheron &raquo;</TD></TR><TR><TD CLASS="quote">def. not!
90% of the time when people complain about synthetic oil being bad, it's because they switched from it to a non-synthetic and screwed up their seals</TD></TR></TABLE>
Wrong info and common myth, synthetic and dino are totally compatible.
Old Nov 9, 2004 | 07:29 PM
Dirt's Avatar
Switching from synthetic to conventional oil is plenty safe in a modern engine. More than enough R owners have used M1 5w30, switched to a conventional oil or tried a higher weight (10w30, 10w40) and have reduced oil consumption by doing so.
Learn about oil here... http://theoildrop.server101.com/cgi/ultimatebb.cgi ... and try a 10w30.
Old Nov 9, 2004 | 07:54 PM
Seedc2's Avatar
Default Re: safe to switch back to conventional oil from synthetic?? (BrewCityR)
switching from mobil 1 5w-30 synthetic to castrol gtx 10w-30
Old Nov 9, 2004 | 08:13 PM
IBriaIN's Avatar
Default Re: safe to switch back to conventional oil from synthetic?? (sim shadeee)
Royal Purple! or REDLINE!
Old Nov 9, 2004 | 08:29 PM
Matty.'s Avatar
Default Re: safe to switch back to conventional oil from synthetic?? (IBriaIN)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IBriaIN &raquo;</TD></TR><TR><TD CLASS="quote">Royal Purple! or REDLINE!</TD></TR></TABLE>
royal purple.
Old Nov 9, 2004 | 08:30 PM
rodimus's Avatar
royal purple sucks compared to castrol 0w30 (german), which is
group ACEA A3 rated.
Matty.'s Avatar
hope so i just did it on my wifes car.
&lt;--- cheapo
Old Nov 9, 2004 | 08:32 PM
yoshi234's Avatar
I shoot brides
sure it's safe. I just went from Castrol syntec to chevron dino juice. Didn't have a choice in this matter, since mikehonda did emergency dipstick t00b repair
Old Nov 9, 2004 | 08:36 PM
Seedc2's Avatar
Default Re: safe to switch back to conventional oil from synthetic?? (EVOL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EVOL &raquo;</TD></TR><TR><TD CLASS="quote">
group ACEA A3 rated.</TD></TR></TABLE>
so what does that mean?
Old Nov 10, 2004 | 07:05 AM
Chubz's Avatar
I used to burn a quart at least every oil change, but i switched to the german castrol and i burn maybe a quarter quart and thats it
Old Nov 10, 2004 | 07:08 AM
totsie7944's Avatar
Default Re: safe to switch back to conventional oil from synthetic?? (Chubzilla)
Generally synthetic oil burns faster from my experiences. I just castrol GTX 5w30 and it seems to burn about a quart, maybe a little less, b/t oil changes.
S2kGuy07
Honda S2000
10
May 18, 2007 10:26 AM
dc4teg95
Feb 19, 2007 03:34 PM
Bngo731
Feb 1, 2006 04:49 PM
mattmw88
Apr 29, 2004 01:52 PM
obd1gsr
Dec 25, 2003 09:48 PM
