CRX Si Gas tank help
Old Nov 9, 2004 | 05:45 PM
CRX_Type_R's Avatar
Default CRX Si Gas tank help
does anyone know how to take out a gas tank from a 91 CRX Si?
Old Nov 9, 2004 | 05:48 PM
tRex99's Avatar
Default Re: CRX Si Gas tank help (CRX_Type_R)
no i dont but why u taking it out??
Old Nov 9, 2004 | 05:51 PM
Sharpview's Avatar
1.disconnect battery
2. relieve gas pressure @ filter
3. drain gas from tank
4. disconnect all gas lines going into tank
5. disconnect sending unit
6. unbolt straps holding tank in
Old Nov 9, 2004 | 05:52 PM
HondaCivicSiR1's Avatar
the easiest way to do is to get the chilton or haynes book for ef's
Old Nov 9, 2004 | 05:55 PM
eumoria's Avatar
tools: candle, large icepick, jack / jackstands, 10mm ratchet, extra gasoline
for this removal I recommend dousing yourself in gasoline first... it'll help.
01 - light candle under tank
02 - start whacking at it with icepick
03 - seek medical attention
Sharpview's method may be more practical.
Old Nov 9, 2004 | 06:00 PM
CRX_Type_R's Avatar
Default Re: CRX Si Gas tank help (eumoria)
My gas gauge doesn't go less than half so I want to see if there is anything inside my gas tank. Should I take a look at my gas tank or check the gauge first?
Old Nov 9, 2004 | 06:09 PM
check the sending unit maybe it not working right it would be where the back seat would be (if you had one) under the carpet
Old Nov 9, 2004 | 06:10 PM
drdisco69's Avatar
Default Re: CRX Si Gas tank help (HondaCivicSiR1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaCivicSiR1 &raquo;</TD></TR><TR><TD CLASS="quote">chilton or haynes book for ef's </TD></TR></TABLE>
Helms 4 life. As much as I like wrong instructions...
Try testing the gauge before you get fuel all over yourself, but the sender may really be bad.
Old Nov 9, 2004 | 07:10 PM
tRex99's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eumoria &raquo;</TD></TR><TR><TD CLASS="quote">tools: candle, large icepick, jack / jackstands, 10mm ratchet, extra gasoline
Sharpview's method may be more practical. </TD></TR></TABLE>
Old Nov 10, 2004 | 08:56 PM
CRX_Type_R's Avatar
how would I know if the fuel sender is bad?
Old Nov 12, 2004 | 10:38 AM
if you have a voltage meter than check and see if it is getting 12 volts but to find that out you have to turn the key on
pepsi813
Honda CR-V & Element
May 19, 2019 12:41 PM
dc4b20
13
Apr 16, 2010 07:01 PM
redef90si
Feb 25, 2010 10:50 PM
dmckrazy45
May 26, 2006 05:15 AM
STN_Pat
Oct 2, 2004 07:02 PM
