window trouble, anyone know?
Old Nov 9, 2004 | 05:30 PM
90hatchie's Avatar
Default window trouble, anyone know?
ok well someone busted out my window and my brother has a friend thats father runs a local junkyard, to make the story short he went and got the window and when i go to put it in turns out its the wrong window. mine looks like it just glues in and sits there ( to the arms comin up) but the one i have has the parts comin down that would glue in then another little part with holes for screws. anyone know what happend? and what window i have? and what coulda caused me gettin the wrong window? is there a difference in where the car was assembled?
anyhelp would help.
Old Nov 9, 2004 | 05:46 PM
tRex99's Avatar
Default Re: window trouble, anyone know? (90hatchie)
well sounds like a rig job to me....should have 2 little black pieces with holes in there for screws and thats it...bolt to the window regulator and thats it...
Old Nov 9, 2004 | 05:52 PM
90hatchie's Avatar
Default Re: window trouble, anyone know? (tRex99)
ok so maybe im wrong and mine does screw in?..... i couldn't even figure out how to get to the window. i got the door panel off and then there the inside metal of the door and behind that is where the window goes. can i get to that? or what do i do. anyone know of a how-to somewhere?
Old Nov 9, 2004 | 06:14 PM
90hatchie's Avatar
ok i think i got it now..... i need to roll the window down completley and i should be able to get to the bolts , i guess i just couldn't see them the way i was tryin to do it.
if im wrong someone tell me
Old Nov 9, 2004 | 06:37 PM
didyouhearthat's Avatar
You're right. Roll it all the way down, remove any excess from the broken window. Slide the new window down and line up the holes on the window brackets with the holes on the regulator and screw them in. The piece on the regulator that the window mounts to moves horizontally left and right.
Old Nov 9, 2004 | 07:07 PM
tRex99's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by didyouhearthat &raquo;</TD></TR><TR><TD CLASS="quote">You're right. Roll it all the way down, remove any excess from the broken window. Slide the new window down and line up the holes on the window brackets with the holes on the regulator and screw them in. The piece on the regulator that the window mounts to moves horizontally left and right.</TD></TR></TABLE>
Old Nov 10, 2004 | 11:52 AM
90hatchie's Avatar
alright, thanks guys i think i got it now. too bad i cant get to my car till saturday.
crxaddikt
17
Jan 13, 2015 04:04 AM
deerman2701
Nov 27, 2007 05:59 AM
da_33
Oct 10, 2007 08:23 AM
Knightmare69
Apr 24, 2006 09:24 AM
io_burn
Oct 14, 2001 08:27 PM
