how do i know if its a gsr tranny?
Old Nov 9, 2004 | 04:54 PM
jaydm ferio's Avatar
Default how do i know if its a gsr tranny?
like it says, how do i know if i have a 2000 gsr tranny? is there a stamp on it? if so where is it located and what should it say. thanx alot.
Old Nov 11, 2004 | 04:23 AM
Anti-Drama Queens's Avatar
Default Re: how do i know if its a gsr tranny? (jaydm ferio)
you'll have to open it up..and count the teeth on the final drive...if 66, then its a gsr tranny
Old Nov 11, 2004 | 04:28 AM
ki3t's Avatar
This user can set his title.
Default Re: how do i know if its a gsr tranny? (mr_ducksauce)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr_ducksauce &raquo;</TD></TR><TR><TD CLASS="quote">you'll have to open it up..and count the teeth on the final drive...if 66, then its a gsr tranny</TD></TR></TABLE>
Wow, that's alot of work. No other ways?
Old Nov 11, 2004 | 04:42 AM
dFreezy's Avatar
Default Re: how do i know if its a gsr tranny? (ki3t)
my gsr tranny has a 'J4D' stamp on it
Old Nov 11, 2004 | 08:14 PM
stumpyf4's Avatar
If it has the VIN plate on it still then you should be able to pick out DC2. However DC2 indicates GS-R or ITR so you may have either.
Old Nov 13, 2004 | 06:37 AM
scientisthonda's Avatar
Default Re: how do i know if its a gsr tranny? (stumpyf4)
it looks diffrent than a 99 si
Old Nov 13, 2004 | 07:33 AM
Jowee's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stumpyf4 &raquo;</TD></TR><TR><TD CLASS="quote">If it has the VIN plate on it still then you should be able to pick out DC2. However DC2 indicates GS-R or ITR so you may have either.</TD></TR></TABLE>
If it says DC2 or DB8 on the tranny vin plate it's a GSR. You'll know it's an ITR tranny if you can look straight through the part where the axles bolt up.
Old Nov 13, 2004 | 02:16 PM
stumpyf4's Avatar
Default Re: how do i know if its a gsr tranny? (ITR 98 1162)
oops.. forgot about the 4door GS-r that we didn't get up here in Canada.
Old Nov 13, 2004 | 02:35 PM
s2kkid's Avatar
Hey guys, i dont know where the vin plate is on mine, My trans is out of the car, and i looked all over it. the car has allot of miles on it, so its very well able to have been taken off over the years.
The barcode sticker on the trans says -
Y80- 1045687
Gsr?
Old Nov 13, 2004 | 03:36 PM
Jowee's Avatar
Default Re: how do i know if its a gsr tranny? (vtecluder97)
Y80 can be a USDM/JDM ITR, GSR, or LS.
Old Nov 13, 2004 | 05:05 PM
s2kkid's Avatar
ok, wheres something direct i can tell?
Old Nov 13, 2004 | 05:33 PM
gsr-2nr's Avatar
easiest way to c if u have a gsr tranny is go to drive at 80mph in 5th gear if ur at 4000rpm u gotta gsr tranny
fredsintegra
Jan 3, 2007 04:22 PM
5150CRX
Jan 25, 2006 06:19 PM
93si-hybrid
Jul 3, 2004 03:25 AM
RACESMART
May 14, 2004 08:26 PM
1999all_motoR_teg
Jun 3, 2003 07:26 PM
