how many washers did you use for your rear camber adjustment
Old Nov 9, 2004 | 04:02 PM
Arv's Avatar
Arv
Default how many washers did you use for your rear camber adjustment
My rear camber readings are -0.8 and 1.0 degrees how many washers do I need to put in? It said in the DIY at accordinglydone.com that you use one washer for a half a degree or use two washers for a 1.5 inch drop. Well my drop is about 1.25" (Tok Illumina kit). I’m afraid 2 washers would set me to positive on one of my wheels.
What was your before and after readings on the rear? How many did you use? Also, since I'm only using 2 washers max on each side I don't have to replace the 1-3/4" (45mm) bolts for the rear UCA right?
Thanks!
Arv
pinks11
Suspension & Brakes
Dec 7, 2007 06:43 AM
huge230
Apr 8, 2006 05:22 PM
sleepyEK
Nov 25, 2003 09:27 AM
Night Kid
Nov 27, 2001 10:04 PM
