Head gasket leak
Old Nov 9, 2004 | 02:25 PM
chop suey's Avatar
Default Head gasket leak
I just rebuilt my gsr motor for a turbocharger, and I had a machine shop bore it out for oversized pistons and did a complete head rebuild (including resurfacing the head). I put the head on with arp studs and an OEM head gasket with copper spray, but it seems to be leaking oil from the head gasket somehow. Why is this happening and how do I fix it?
Old Nov 9, 2004 | 03:25 PM
chop suey's Avatar
Default Re: Head gasket leak (chop suey)
anyone?
Old Nov 9, 2004 | 03:28 PM
SOHC Gord's Avatar
did u tourqe the arp studs right they mit not be tourqed down enough
Old Nov 9, 2004 | 05:25 PM
dkautospray999's Avatar
Default Re: Head gasket leak (SOHC Gord)
Did you have the head and block decked before you reassembled the motor? I would just recommend pulling the head again and checking both surfaces with a straightedge for warpage. Also were both surfaces (block and head faces) cleaned off? Just a couple other things to think about.
Old Nov 9, 2004 | 05:47 PM
Newt Dog's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chop suey &raquo;</TD></TR><TR><TD CLASS="quote">I just rebuilt my gsr motor for a turbocharger, and I had a machine shop bore it out for oversized pistons and did a complete head rebuild (including resurfacing the head). I put the head on with arp studs and an OEM head gasket with copper spray, but it seems to be leaking oil from the head gasket somehow. Why is this happening and how do I fix it?</TD></TR></TABLE>
Are your stud's all the way down in the block before you torqued the head?? If not, Your head gasket is not going to seal properly. I had the same porblem.
integraturbo
Oct 29, 2008 10:56 AM
drumminforev
11
Jan 4, 2007 01:39 PM
Dartanian
Jun 13, 2006 10:40 PM
Squirtin EGsr
17
Sep 26, 2005 09:13 PM
b18cx
Jun 10, 2004 03:31 PM
