fluid damper
Old Nov 9, 2004 | 02:15 PM
JBBNJ609's Avatar
Default fluid damper
ok so i was looking around i i found this :
http://www.fluidampr.com/honda.htm
i have a daily driven integra that is allmotor. . i have a stock 130k crank pulley, im wondering if this is a good buy to maybe have things run more smoothly and SAFELY and longevity is very important . .
anyway im keeping my a/c and PS for now atleast
Old Nov 9, 2004 | 05:51 PM
therealpoorboy's Avatar
Default Re: fluid damper (jason bouchard)
its a very good product. and it will definetly help longevity of bearings.
Old Nov 9, 2004 | 10:21 PM
JBBNJ609's Avatar
Default Re: fluid damper (therealpoorboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by therealpoorboy &raquo;</TD></TR><TR><TD CLASS="quote">its a very good product. and it will definetly help longevity of bearings.</TD></TR></TABLE>
very good because i spun a bearing twice already
Old Nov 10, 2004 | 06:47 AM
JBBNJ609's Avatar
bump , is this safe and good for a daily driver ??????
Old Nov 10, 2004 | 11:00 AM
743power's Avatar
Default Re: fluid damper (JOHN WAYNE)
Go for it man, if you got the $$ it's a really good investment.
I believe all Nascar motors run the race version.
Old Dec 3, 2004 | 10:37 AM
Tim2179's Avatar
eight equals equals equals D
Community Builder
Loved
Default Re: fluid damper (743power)
An aftermarket dampened crank pulley will do a decent job of reducing harmonics that cause bearings to wear and will also reduce timing scatter at high RPM. A stock pulley is fine on a stock motor. Once you start to modify them though beyond OEM spec HP, it's good idea to get a good crank damper to handle the increased internal stress on the crank and bearings.
NASCAR does not use the fluid damper. They all use ATI's "Super Damper" or the GM Performance brand - which ATI manufactures for GM.
Fluidampr uses a viscios fluid to absorb harmonics, while the ATI unit uses a series of elastomer 'O-rings' wrapped around an inertia weight to absorb harmonic vibrations.
To the observer - these o-ring dampers all look the same, but in reality the o-rings are tuned by using o-rings of various durometers (hardness) to make them more effective then the fluid variety. Over time the fluid can harden and crystylize. While the same holds true for the elastomer type - over time, they too can harden, however the ATI variety is rebuildable and can be overhauled for far less then the cost to replace the entire unit.
They are perfectly safe to use on unmodified motors, however you will not really see any benefit at stock levels.
Depending on what accessories you run off the crank pulley, you can find versions with or without stock drives for the P/S & A/C.
Modified by Tim2179 at 4:24 PM 12/3/2004
Old Dec 3, 2004 | 12:35 PM
Rocket's Avatar
Default Re: fluid damper (Tim2179)
Jason,
3 Letters.
Old Dec 3, 2004 | 12:44 PM
JBBNJ609's Avatar
Default Re: fluid damper (Rocket)
ATI ??
Old Dec 3, 2004 | 12:46 PM
Rocket's Avatar
B I N G O
The "other" stuff was originally designed for low rpm desiel motors. Can you say max torque at 1500 rpms and max power and 2500 rpms (talking about the desiel motors).
ATI are run on Cup motors spinning 10k rpms for 500 miles for 2+ hours. Ever hear a SBC run a t 10K? I haven't but I can imagine. Scary
Old Dec 3, 2004 | 12:47 PM
JBBNJ609's Avatar
do you know how much they run ? ( a/c and ps too)
Old Dec 3, 2004 | 12:48 PM
Rocket's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jason bouchard &raquo;</TD></TR><TR><TD CLASS="quote">do you know how much they run ? ( a/c and ps too) </TD></TR></TABLE>
I can get a pretty good deal on them.
Old Dec 3, 2004 | 12:50 PM
JBBNJ609's Avatar
YGPM
Old Dec 3, 2004 | 12:54 PM
Rocket's Avatar
Race versions have been sold for a while. The street versions are supposed to be ready by the begining of the year.
These are a true benefit to your motor. Tbone has 250+ dyno pulls on his ATI equipped motor.
Old Dec 3, 2004 | 12:56 PM
JBBNJ609's Avatar
very good, im sold haha
Old Dec 3, 2004 | 01:01 PM
Rocket's Avatar
Very coo. Just try to get you guys the good stuff.
egkyran
12
Jan 17, 2008 12:16 PM
BlwnBlue
Dec 20, 2007 11:43 AM
PhatBoy5015
Aug 5, 2006 02:26 PM
JustLooking
Nov 23, 2003 02:12 PM
slofu
Aug 18, 2003 08:26 AM
