IS my SAFC broken?
Old Nov 9, 2004 | 02:14 PM
x2gold's Avatar
Default IS my SAFC broken?
Here's the story, I'm looking for some answers. I had LS turbo with SAFC and 450's in old hatch. Bought new hatch and put SAFC into it and it doesn't turn on. It worked perfectly in my old car and it was lying around for a few months, when I went to wire it up, it doesn't even turn on. My question is, if the wiring is correct, could the SAFC be ruined or bad?
I checked the wiring several times, and belive i'm good there. I just got the car and it does have a bad battery ( I was showing 11.2 volts). I charged it overnight on trickle and it was 12.67 and still no power. I have power at the power wire and it is grounded correctly.
I'm puzzled, as I didn't even put the motor in yet - I just wanted to wire up the SAFC - but even that isn't working.
ALSO - Can I check my SAFC by plugging it into a car that is already wired with one to check and see if it is functional.
BTW the car is a 98 Civic HB CAN production.
Thanks.
Old Nov 9, 2004 | 02:27 PM
notstock93's Avatar
Default Re: IS my SAFC broken? (x2gold)
wire it in to a working stock car. See if it works. If it doesnt, buy mine.
Old Nov 11, 2004 | 09:25 AM
x2gold's Avatar
Default Re: IS my SAFC broken? (notstock93)
bump.. help a brother out
Old Nov 16, 2004 | 11:46 AM
x2gold's Avatar
anyone got ideas?
Old Nov 16, 2004 | 01:16 PM
sleepin91teg's Avatar
There are 2 grounds...make sure both are hooked up...make sure your power is connected where it needs to be, go the apexi-usa.com theres a guide for it...
Old Nov 16, 2004 | 04:15 PM
x2gold's Avatar
Default Re: IS my SAFC broken? (sleepin91teg)
Danka... did it, used volt meter to check grounds and power. Correct Ranges -
P.S- used Helms to get voltage with ign off and in acc.
jdmthug
Mar 11, 2007 11:04 PM
'99luder
Audio / Security / Video
Jun 4, 2005 08:01 PM
TurboJesse
Apr 29, 2003 01:33 PM
Garage Battle
Jun 28, 2002 09:26 PM
