how do make adjustment to my koni yellow shocks
i just got some koni yellow adjustment shocks from my boy and i don't know how to adjust them my other shock adjust from the top of the shock with a tool they give you with the shock but when i got these there was no tool what do i use to adjust it and how thanks for the help
At first, I was surprised you were having a hard time finding the part since someone had already provided the website (koni.com)
So, out of curiosity, I tried going to koni.com and after 3-4 minutes with no success of finding where I could order the ****, I dug around and found an answer for you.
1. Go to http://www.koni-na.com (not koni.com! koni.com is the global site, koni-na is the north american site)
2. Click on ONLINE STORE
3. Select category --> *****/Accessories and click CONTINUE
4. You should be directed to this page
http://www.koni-na.com/cgi-bin...r=yes
5. I'm not sure if you would need the SHORT or LONG **** (insert random ***** joke here). If anyone can answer this one, please go for it.
Otherwise you should just use the contact info at the bottom of the page.
I have Koni yellows on my crx. If you need a pic of the bottom of the ****, just PM me.
Hope this helps
Hope this helps
What car are your shocks for?
Do you know the koni part #?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kurinto »</TD></TR><TR><TD CLASS="quote">His konis may not be externally adjustable. In that case I believe you twist the shock to adjust it.</TD></TR></TABLE>
....true.
....true.
dingusjt
Feb 7, 2003 11:46 AM
adjust, adjustment, car, civic, honda, installation, jack, knob, koni, settings, shock, shocks, wwwkonicom, yellow, yellows
