Slightly inconsistent idle...
Old Nov 9, 2004 | 12:37 PM
crizkeeth's Avatar
Default Slightly inconsistent idle...
When cold or warm, doesnt matter what accessories are on, etc. My '91 Accord has a slight inconsistency with the idle... it will slightly "sputter" just a little every few seconds. What might this be due to? I dont have much experience with Hondas as I just purchased this car.
I read that from 90-93 the accords had a lot of trouble with the distributor failing... might this be the cause? Thanks,
Chris
Old Nov 9, 2004 | 12:49 PM
-RedneckDave-'s Avatar
Working
Default Re: Slightly inconsistent idle... (crizkeeth)
Sounds normal and nothing you should be worried about. You could try and change your plugs and fuel filter and do a general tune up and see if that helps, but I would not be too worried about your idle.
Old Nov 10, 2004 | 06:01 AM
93CivicSI's Avatar
Seafoam (search) or Honda Throttle body cleaner - and check your plugs....
Old Nov 10, 2004 | 07:46 PM
crizkeeth's Avatar
Thanks for the replies :-)
My concept of a tune up involves replacing the following items:
- Plugs
- Wires
- Cap
- Rotor
- O2
- Fuel Filter
- Coil (maybe)
Anything else? Does this sound like a proper tune up?
Old Nov 10, 2004 | 07:47 PM
crizkeeth's Avatar
Default Re: Slightly inconsistent idle... (93CivicSI)
I will do a search on seafoam and clean the throttle body... thanks 93Civic
Working
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crizkeeth &raquo;</TD></TR><TR><TD CLASS="quote">Thanks for the replies :-)
- Plugs
- Wires
- Cap
- Rotor
- O2
- Fuel Filter
- Coil (maybe)
Anything else? Does this sound like a proper tune up?</TD></TR></TABLE>
That sounds like a pretty good list. If that does not help it then you may want to try some seafoam like 93 suggested.
Old Nov 11, 2004 | 02:52 PM
crizkeeth's Avatar
Damn, these Honda ignition parts are bank!! Im formally a chevy guy and other domestic vehicles... parts are much cheaper. Anyone have any good resources for cheap parts?
Old Nov 11, 2004 | 07:52 PM
Working
Here try this place they are pretty good and pretty cheap.
http://www.hondaautomotiveparts.com/
SpookyEF
12
May 18, 2019 01:22 PM
MKIRSCH02
Feb 2, 2013 01:34 AM
Ntense_Civic
Apr 20, 2012 04:47 PM
underb00steg6
Jun 9, 2008 09:46 PM
2000_Civic_Si
Sep 9, 2002 11:27 AM
