1991 accord, cranks, no start.
Old Nov 9, 2004 | 12:23 PM
techintraining's Avatar
Default 1991 accord, cranks, no start.
Here is the problem, the car will crank but will not start. The battery is at 12.35volts which I know is alittle low as opposed to 12.6. When I crank the car it smells like gas, I would assume the car is getting gas. I did not have a spark tester on me today but I will be checking for spark tomorrow when I trailor it to school. Does anyone know what I should check? I will be hooking up a flow gauge, spark tester, and scope tomorrow at school but I am not familar with this type of dis system. When I look at the coil pack it seems to have no external 12volt feed going into it (I was going to hit that 12v wire with a test light to see if it was good). Any help or suggestions would be greatly appreciated. Thanks.
Old Nov 9, 2004 | 01:59 PM
Default Re: 1991 accord, cranks, no start. (techintraining)
bump.
Old Nov 9, 2004 | 03:56 PM
Suke's Avatar
I would bet $50 that your distributor is bad. I just replaced mine on my 1990 accord. You can take it somewhere to hook it up to a computer if you wish.
I bought my distributor from advanced auto parts.. unfortunately the part the gave me gave me trouble and eventually went bad.. but they give a liftetime warranty so I got a new one free and now everything is fine. (maybe just bad luck)
Anyway.. it's the distributor I'm 99% sure and I would check your sparkplugs while you are at it to see if you need to put some new ones in.
Old Nov 10, 2004 | 02:53 PM
Well, pay up, its was not the distrib. It was the coil, for the coil ohm checked within specs but must have been internally shorted. Hooked up a scope and the pattern showed the primary to be good.
Old Nov 10, 2004 | 03:22 PM
bodiez's Avatar
Hit the floor!
Default Re: (techintraining)
Hahahah owned
Old Nov 10, 2004 | 10:12 PM
hawkmgc's Avatar
Stock up on the coil, it is the most known part to go bad.
sad part is you can get them for 35 bucks but everyone just goes to bone yard and buys a whole distrib. for 150 bucks and trashes the old one with just a bad coil. Was numb nutzer
oconnell262
Aug 1, 2015 10:38 PM
treyfeezy
Aug 10, 2011 06:03 AM
civicboisi
Nov 29, 2009 06:09 PM
johanna
Oct 22, 2007 09:13 AM
digital_cowboy
Jul 7, 2007 06:37 PM
