NEED HELP, gsr engine wire harness...
Old Nov 9, 2004 | 11:49 AM
l2Y4N's Avatar
Default NEED HELP, gsr engine wire harness...
my gsr had been misfiring randomly, ends up its a short in the engine harness. well the dealership wants 830 for a new one plus 400 for installation. f that. i need to know what other integra harnesses work for a 96 obd2 gsr, and how hard is it to do a harness swap? i'm a fairly capable mechanic and it seems a harness would be simple. thanks in advance, and heres a pic so this thread gets some attention...
Old Nov 9, 2004 | 12:02 PM
omiehomie's Avatar
Default Re: NEED HELP, gsr engine wire harness... (integraTracer)
i personally would never go to the dealership unless it was my last resort.
i would check with LKQ salvage yards and just tell um what your lookin for and they will hook you up
good luck
Old Nov 9, 2004 | 12:49 PM
rgaray's Avatar
Did they say which section, or is it the entire harness.
Old Nov 9, 2004 | 01:29 PM
l2Y4N's Avatar
Default Re: (rgaray)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rgaray &raquo;</TD></TR><TR><TD CLASS="quote">Did they say which section, or is it the entire harness.</TD></TR></TABLE>
they said it was a short that affected the injectors, but they recommended getting a whole harness instead of trying to repair or replacing the section that was ruined.
Old Nov 9, 2004 | 01:30 PM
l2Y4N's Avatar
Default Re: (integraTracer)
so is it easy enough to replace the harness myself?
Old Nov 9, 2004 | 01:48 PM
blacktegmd's Avatar
its easy it just depends on how capable you are it can take a couple of hours or it can take a day or two..
Old Nov 9, 2004 | 01:50 PM
l2Y4N's Avatar
Default Re: (blacktegmd)
ok, thanks dude. anyone know about what other harnesses work for my car??? it seems to me any obd2 b series vtec car should work. anyone?
Old Nov 9, 2004 | 01:52 PM
blacktegmd's Avatar
and all you need is a phillips and flat head screw driver and a pair of needlenose,and just take your time... and on the old harness mark where the connectionis with a piece of tape. you should have a problem ....
blacktegmd's Avatar
my fault you should have NO problem
Old Nov 9, 2004 | 03:24 PM
Cjsls's Avatar
you should just take the time to look at your current harness yourself. it could be something as simple as some frayed wires. Which you could easily fix yourself and save yourself alot of $$$.
Old Nov 9, 2004 | 09:48 PM
l2Y4N's Avatar
Default Re: (Cjsls)
ok, thanks, i'll check that out. but if i have to replace the old one, anyone know what else works? i really don't want to shell out 500 bucks (cheapest ive found so far) for a freakin harness.
Old Nov 10, 2004 | 08:07 AM
l2Y4N's Avatar
anyone else?
Old Nov 10, 2004 | 10:21 AM
Oleg's Avatar
I would suggest that you pull up an electric diagram for your car from like, All Data. (if you are mechanic then you probably have an acces to it) Get a multimeter and go throuth the harness wires that consern ignition system, check for opens and shorts..... it'll take a while, but you will be able to save $$. P.S. Do the diagnosis one more time, it might not be the harness and you definitly don't want to find out about that after you'll put the new one in
wunfstgsr
Audio / Security / Video
Dec 7, 2009 07:41 PM
Mr. KDes
Feb 10, 2009 11:27 AM
TwoKSiR
Dec 18, 2008 10:28 AM
EGKREW
Nov 20, 2008 10:02 PM
topspeed86
Jul 19, 2003 09:01 AM
