power door locks on gsr
Old Nov 9, 2004 | 11:46 AM
STUCKED's Avatar
Default power door locks on gsr
what is wrong when the locks doesnt work? check the fusees and they are still good. is there something else i might not be looking. any help would be useful
Old Nov 9, 2004 | 11:51 AM
TrueUntilDeath.com's Avatar
Default Re: power door locks on gsr (STUCKED)
it could be unplugged from underneath the door panel
Old Nov 9, 2004 | 11:53 AM
BlueIntegraBoy's Avatar
Happened to me on my old GSR. Lock would work but unlock wouldn't work. I sold the car before I could fix it. It might be the main lock switch on the driver door. It may need replaced or fixed. If that switch goes out, your locks don't work.
Old Nov 9, 2004 | 12:08 PM
STUCKED's Avatar
Default Re: power door locks on gsr (BlueIntegraBoy)
alritey... ill look into that. so thingy is under the door you say?
Old Nov 9, 2004 | 12:14 PM
Dc2 Powered's Avatar
my driverside works but my passenger door doesnt work
Old Nov 9, 2004 | 04:54 PM
integ6657's Avatar
most likely a bad power lock actuator. I would look there. And if I'm not mistaken{which I may be } the drivers side actuator controlls the other doors.
Old Nov 9, 2004 | 06:03 PM
AGeisinger's Avatar
Hook the motor to a jump pack.... ythere should be either two or three wires if there is two then the one is up and the other is down and it is grounded by the car .
If there are there three then one is up one is down and one is the ground.
If they dont work when u touch them to the jump pack then the motor is bad...
Does the switch have the driver and passenger if so are they both broke if so its the switch or there unpluged if one works then it might be just the motor but test the motor that will eliminate alot.....
Old Nov 10, 2004 | 09:20 AM
if it was the aculator wouldnt it work but just make a loud *** sound like the old 94 accords used to
Kdeezy95
Nov 11, 2013 12:42 PM
b20acura
25
Feb 11, 2012 04:45 AM
JMod
Aug 17, 2003 05:38 AM
Calavera
Jun 13, 2003 02:56 PM
