gsr swap in a crx
need a little help. im kind of new at this and i was wondering what exactly what i need and what i have to do to install a gsr in a 89 crx si. i know hasport makes a wiring harness and i need to get a cable tranny also i need shift links and axles, but i also heard that i have to get different hubs. so any advise you guys could give would help a lot thanks.
u'll need the motor and tranny.. if u have money u can use the hydro tranny with the hasport cable/hydro conversion.. mounts, linkage, axles, ecu.. etc.. you'll need to get the b16 driver side mounting studs that are on the block... i have a gsr/itr in mine right now.. most of the plugs plug up to the motor minus the fan switch.. you'll need to re-wire that.. currently im running a pr3 with the gsr/itr motor until i get the funds to buy everything i need for the obd1 conversion..
Doesn't anybody every check the sticky FAQ anymore? I've seen several threads where the answer s can be found in the FAQ.
http://www.geocities.com/droppedcrxsi/
https://honda-tech.com/zerothread?id=953089
SkunkCrxSi
Jul 2, 2004 11:38 AM
