Civic Wheel Bearings
Old Nov 9, 2004 | 08:50 AM
sony9999's Avatar
Default Civic Wheel Bearings
I have a 98 DX coupe Civic and my wheel bearings are noisy as hell.
Anyone have any idea what aftermarket parts are on the market for wheel bearings? All I was able to find was a NTN brand bearing. Is it best to purchase authentic Honda parts?
I'm running with a 17" rim and a 1.75" spring drop. New camber and shocks have also been installed. With that said, is it more likely that my new bearings will wear faster because of more stress put on them by the larger rim?
Old Nov 9, 2004 | 09:09 AM
Hatchy-Ownzjo0's Avatar
H-T Poker champion
Default Re: Civic Wheel Bearings (sony9999)
Stick with OEM wheel bearings.. The wheel bearings are not specificaly designed to be used with bigger wheels and a drop. The drop most likely puts more stress on the bearing and axles due to the angel change that it causes, but it shouldnt wear out anytime soon if you replace the bearing. Should go for a good 100k miles or more.
Old Nov 9, 2004 | 09:13 AM
93CivicSI's Avatar
BUY OEM Bearings..... Nothing is equal... wheel and tire size will have little if any effect on the life expectancy.
Old Nov 9, 2004 | 09:25 AM
snatch's Avatar
Default Re: Civic Wheel Bearings (93CivicSI)
I agree, stick with OEM quality material
Old Nov 9, 2004 | 09:42 AM
jdm123's Avatar
Default Re: Civic Wheel Bearings (******)
yup i agree to. oem honda is teh ****
Old Nov 9, 2004 | 09:50 AM
EK45VTi's Avatar
Default Re: Civic Wheel Bearings (jdm123)
Honda OEM for wheel bearings is in most cases KOYO...
Honda also uses NTN bearings for i.e. tranny differential...
So I guess you can't miss if you buy NTN bearings cos they are also qualified enough to be "Honda OEM"...
But if you want to pay extra dlrs go ahead...
Old Nov 9, 2004 | 10:10 AM
6SPD_EK's Avatar
Default Re: Civic Wheel Bearings (KKVTi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KKVTi &raquo;</TD></TR><TR><TD CLASS="quote">Honda OEM for wheel bearings is in most cases KOYO...
But if you want to pay extra dlrs go ahead...</TD></TR></TABLE>
I agree I got NTN bearings $30 each instead of over $50 each for OEM...& yes honda does use NTN parts
some other areas you may want to stick with OEM for fitment & quality IMO
Old Nov 9, 2004 | 10:30 AM
ejprimo's Avatar
Default Re: Civic Wheel Bearings (adirondackR)
i needed a new front wheel bearing on my civic, so i just went out and bought a complete used front brake and knunckle from an integra for $140.
Animefun
Suspension & Brakes
10
Jul 23, 2013 01:28 AM
2k.civic.si
Jun 28, 2012 02:19 AM
avio
Dec 20, 2010 08:16 AM
ketchup
Mar 10, 2008 06:06 PM
eda6
Suspension & Brakes
Jun 23, 2005 09:09 PM
