comp cams new turbo cams?
Old Nov 9, 2004 | 07:16 AM
street_strip's Avatar
Default comp cams new turbo cams?
I know most people are saying to go with stock gsr cams. After looking at the specs on some of the new cams I was wondering if you guys think there would be any benifit to using the stage 2 or higher on B series running 15psi or higher.
I want to run around 17psi on my built gsr motor at 9.5:1 cmp. Do you think it would be worth the money?
Later Street_strip
Old Feb 14, 2005 | 01:02 AM
loserface's Avatar
Default Re: comp cams new turbo cams? (street_strip)
bump
Old Feb 14, 2005 | 01:12 AM
If You Slip You Die's Avatar
Default Re: comp cams new turbo cams? (loserface)
bump finding out for a homie but info bout the stage 4's or what other cams would u recommend fully built 84.5mm gsr gt35r
Old Feb 14, 2005 | 08:35 AM
earl's Avatar
The Comp cams will definitely raise the rpm level that you will obtain full torque and horsepower along with raising the max power numbers also.
Old Feb 14, 2005 | 10:32 AM
Default Re: comp cams new turbo cams? (earl)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by earl &raquo;</TD></TR><TR><TD CLASS="quote">The Comp cams will definitely raise the rpm level that you will obtain full torque and horsepower along with raising the max power numbers also.</TD></TR></TABLE>
would you recommend them or some other cams?
Old Feb 14, 2005 | 06:54 PM
earl's Avatar
Default Re: comp cams new turbo cams? (05 EVO VIII GSR)
if the car is on the street, type r's would be great to 600hp
Old Feb 14, 2005 | 08:18 PM
USDM 4G VTEC's Avatar
on my case the D series COMP cam 59300 lowered the point where i start making good torque and expanded theh power curve larger...
now turbo i haull *** on midrange power
Old Feb 14, 2005 | 09:56 PM
SOHC_MShue's Avatar
Default Re: comp cams new turbo cams? (USDM 4G VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by USDM 4G VTEC &raquo;</TD></TR><TR><TD CLASS="quote">on my case the D series COMP cam 59300 lowered the point where i start making good torque and expanded theh power curve larger...
now turbo i haull *** on midrange power</TD></TR></TABLE>
any pics on stock cam vs. 59300 cam? I know with my turbo D the motor stopped making good power way earlier with the stock cam than the 59300.
Old Feb 15, 2005 | 12:25 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by earl &raquo;</TD></TR><TR><TD CLASS="quote">if the car is on the street, type r's would be great to 600hp</TD></TR></TABLE>
yea its his daily driver now since he blew the motor to his beater
Old Feb 15, 2005 | 06:01 AM
im having problems with we - todd
as soon as i can upload the pics, i will post the comparison of the cams
Old Jul 26, 2005 | 06:07 PM
D@nnY's Avatar
Default Re: (USDM 4G VTEC)
street_strip is a scammer piece of ****
FA5civicSI
Honda Civic (2006 - 2015)
Oct 18, 2008 06:19 PM
screaminhatch
Oct 29, 2006 10:46 AM
hoskos
Aug 16, 2006 06:16 PM
EJ8 GSR-T
Jul 21, 2006 11:02 PM
SIReg9
Aug 13, 2003 03:18 PM
