92 Prelude...Taking off Stock Bottom Air Box to your Stock intake.?
Old Nov 8, 2004 | 09:34 PM
mR. Vash's Avatar
Default 92 Prelude...Taking off Stock Bottom Air Box to your Stock intake.?
Would this help for more air? I've seen it done before, but not sure if it works. If you don't understand this, it's the stock intake bottom air box behind your right bumper lense.
Old Nov 8, 2004 | 10:14 PM
mR. Vash's Avatar
Default Re: 92 Prelude...Taking off Stock Bottom Air Box to your Stock intake.? (GsRdHatcH)
anyone?
Old Nov 8, 2004 | 11:14 PM
00LudeLover's Avatar
go for it...i did it. There is a little butterfly valve in there that opens up when you open your throtle, it is connected with a vac line.
cut it, bend it, and tape it closed, i would especially take it off if you have after market intake, if you dont, get one for 30 bucks, and buy a new filter for it.
and you will be set.
Old Nov 9, 2004 | 07:33 AM
mR. Vash's Avatar
Default Re: 92 Prelude...Taking off Stock Bottom Air Box to your Stock intake.? (00LudeLover)
thanks for reply, anyone else?
Old Nov 9, 2004 | 08:06 AM
Monkey Fing a Coconut's Avatar
just get an ebay intake and a good filter, its mostly the stock paper filter that prevents airflow, the box is mainly to muffle the sound so ur basically just making the car louder w/ very minimal gains
Old Nov 9, 2004 | 12:34 PM
mR. Vash's Avatar
Default Re: 92 Prelude...Taking off Stock Bottom Air Box to your Stock intake.? (twistedbydezign)
i've had an aem previous, but i just wanted to make the motor look bone stock and im also tring to hid the header under the stock heat shield (some how custom it) Baiscally all stock look.
Old Nov 9, 2004 | 05:15 PM
black92lude's Avatar
you should take the air box and put a aftermarket cone filter inside the air box....nobody would ever be able to tell
Old Nov 10, 2004 | 11:24 AM
Elkins911's Avatar
Default Re: 92 Prelude...Taking off Stock Bottom Air Box to your Stock intake.? (black92lude)
the resognator does only cut down sound, but it is also warming up the slightly faster. the air needs to travel farther to get to the TB.
Old Nov 10, 2004 | 04:27 PM
SiB16A's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by black92lude &raquo;</TD></TR><TR><TD CLASS="quote">you should take the air box and put a aftermarket cone filter inside the air box....nobody would ever be able to tell
what kind of filter and where can i buy one.? im interested in this subject also.
Modified by SiB16a at 4:06 AM 11/11/2004
EG-SIXV-TEC
11
Oct 27, 2015 12:54 AM
Surfer_Sandman
Dec 26, 2004 02:02 PM
sinfulDB1
Apr 28, 2003 07:35 PM
Integvalier
Aug 28, 2002 04:15 PM
AB16A2T
12
Jun 26, 2002 02:21 AM
