CRX HF with B16A starting problems
I searched on this but didn't find anything like what was going on with mine. I just finished the swap and I went to start it today and it cranked and cranked, it finally fired after I heald my foot on the gas and it idled like ****. I took my foot off and it died right away. I went to start it again and it fired without having to hold my foot down, but it died after a few seconds. It bogs like hell when you try to rev it also. There are no codes thrown either. Any suggestions on what to check? Similar thing happened to my buddy's DA Integra and it was the injectors, but I'm not thinking this is. Any help is appreciated.
From: not riding any bandwagons in, massachusetts, usa
check to see the timing belt isnt off a tooth, distributor rotor is melted and warped away from the contacts and plug wires arent breaking down. did the problem just happen one day or did it occur over a period of time?
Today was the first time I fired it up. The distributor is fine, we had it on my buddy's GSR in a 4th gen and it worked fine. Timing is on also.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BNiceB16 »</TD></TR><TR><TD CLASS="quote">do you have both o2 sensors hooked up </TD></TR></TABLE>
Doesnt matter for startup
what ecu did u use? what injectors?
GSR98EX
Sep 1, 2011 12:09 PM
jonessw20
Jun 6, 2010 04:46 PM
XspeedSi02
Mar 3, 2008 09:51 PM
Simon Tibbett
Jun 21, 2005 01:34 PM
