Couple Questions About Coilovers
I just bought a cheap pair of coilovers for now. Anyway for the days I'm not working I want to be able to just slam it as much as I can without rubbing or anything. Will I need to buy a camber kit if I drop it a lot? Also I'll need an alignment right? Also, if I lower it to much is it possible to blow my shocks? There stock for now. What do you guys think would be a safe drop?
yea if u slame it to the ground u will need a camber kit
i did full coilovers on my accord and my teg
and droped both of them bout 2 inch in the front
and bout 1.5 in the rear on my accord i didnt need
a camber kit but on my teg i did i bought the skunk2
i really like there stuff
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jojoforhelp »</TD></TR><TR><TD CLASS="quote">I wouldnt lower it at all on stock shocks.
Every time you raise or lower the car, you'll need an alignment.</TD></TR></TABLE>
Damn didn't know that, oh well. So you think If I drop it around what orion did I'll be good? Or will I have to worry about my stock shocks?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Beezle »</TD></TR><TR><TD CLASS="quote">
Damn didn't know that, oh well. So you think If I drop it around what orion did I'll be good? Or will I have to worry about my stock shocks?</TD></TR></TABLE>
ya but you dont have to. most of the time that you would need to get an alighment is on the initial install becuase the lca is moving around more then usual. my friend raises and lowers is tanabe ss damper kit every month and he doesnt get any uneven wear on the tires. he doesnt have a camber kit either.
It's not about camber, it's about toe.
Toe changes in addition to camber when the ride height is changed, and toe is what eats tires for lunch if it's not set to within spec.
Fine tuning the height (like 2-3 turns on the collar) shouldn't be too bad, but drastic changes in ride height will require an alignment if you want your tires to last for any significant length of time.
This is why an alignment is always required after lowering the car, because the toe is thrown off after it's lowered.
All this stuff about camber eating tires has pretty much been a misconception over the years.
Thanks for the info. Will I be able to drop my car around 2" all around on stock shocks? Also, what shocks do you recommend? I see a lot of people use Koni Yellows.
i wouldnt lower it with the stock shocks......they are very prone to blowin out with a stiffer suspension.......i'de get a set of koni's if u want good quality.....they are pricy though, look around for deals.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by excoupe97 »</TD></TR><TR><TD CLASS="quote">i wouldnt lower it with the stock shocks......they are very prone to blowin out with a stiffer suspension.......i'de get a set of koni's if u want good quality.....they are pricy though, look around for deals. </TD></TR></TABLE>
Aright cool. Eventually though I want to do a ITR 5 lug conversion, will the struts, coilovers and shocks still fit?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by orion840 »</TD></TR><TR><TD CLASS="quote"> matrix makes a set of
full coilovers 24 point adj.
for 700 brand new there
better than that
or really go all out and save the money
and get some tein
If they're anything like the old Arospeed full coilovers, they're junk (friend had the Arospeed coilovers on his old car, terrible).
better than that
and get some tein
</TD></TR></TABLE>If they're anything like the old Arospeed full coilovers, they're junk (friend had the Arospeed coilovers on his old car, terrible).
well the matrix wasnt near as good as my tein
but they did the job i was able drop it pretty low
and still get a good ride
but the tein are nice
I dropped my Ls on Tanabe DF210 springs with no alignment and my tires have been fine for months , no wear other than normal whatsoever.. and my stock shocks arn't blown yet either... but i plan on gettin Tanabe coils soon
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DarkblueInteg »</TD></TR><TR><TD CLASS="quote">I dropped my Ls on Tanabe DF210 springs with no alignment and my tires have been fine for months , no wear other than normal whatsoever.. and my stock shocks arn't blown yet either... but i plan on gettin Tanabe coils soon</TD></TR></TABLE>
do you drive much? Are your tires super hard?
Most likely you're hurting performance and safety by not having the car properly aligned. Alignment DOES change when a Honda is lowered. No way around it, that's just the nature of the beast. When the ride height is changed, alignment WILL be out of spec, so I would advise having it done, whether or not your tires seem to be abnormally wearing or not.
farkiller
11
Aug 17, 2009 11:07 AM
krysted9354
14
May 19, 2009 02:22 PM
Skunk2 coilovers on tokico shocks. DO I NEED CAMBERS WITH 2inch drop??suspension installation. urgen
Ratchback
Oct 5, 2004 10:19 PM
