problem with ls/vtec in del sol.
Old Nov 8, 2004 | 07:35 PM
tcr03's Avatar
Default problem with ls/vtec in del sol.
ok so i popped my hood today to find that the hood is rubbing on my valve cover. the subframe of the hood has rubbed a line in the blue paint on my cover. has anyone else had any problems with any other b-series motors in a del sol. i know the b16 came in them so i dont see why im having this problem unless the b18b block is taller.
any input would be greatly apretiated(sp)
Old Nov 8, 2004 | 08:51 PM
tcr03's Avatar
Default Re: problem with ls/vtec in del sol. (tcr03)
anyone got any suggestions
Old Nov 8, 2004 | 09:29 PM
jeef84's Avatar
I was under the impression that del sol's came with the same d-blocks the civics did, since they are essentially the same car.
I could be wrong.
Old Nov 8, 2004 | 09:39 PM
tcr03's Avatar
Default Re: problem with ls/vtec in del sol. (jeef84)
they came with d15, d16, and a b16 depending on the model you got.
Old Nov 8, 2004 | 09:51 PM
b18c1eg
Guest
Posts: n/a
Seems odd... I know the b18's are a bit taller, but hardly noticeable.
Has the car been wrecked before? Maybe something is out of whack.
Brad
Old Nov 8, 2004 | 10:03 PM
tcr03's Avatar
Default Re: problem with ls/vtec in del sol. (b18c1eg)
no but i was just informed that the gsr head is also taller to that on top of the block being bigger would expain a bit but i still need sugestions on how to fix it.
Old Nov 9, 2004 | 12:02 AM
AzntaggeR's Avatar
TSPeed Factory
thats odd. my b18c1 clears my hood just find.
Old Nov 9, 2004 | 06:28 AM
tcr03's Avatar
Default Re: problem with ls/vtec in del sol. (AzntaggeR)
yes but the ls block is taller than the gsr block. from what i hear.
Old Nov 9, 2004 | 06:37 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
You could go out and get a new hood with a slight cowl to ensure the clearance.. or you could bang the hood frame with a hammer, or try and raise the hood stops at the corners of your radiator supports for a few extra centimeters of clearance.
Old Nov 9, 2004 | 07:54 AM
pwrofdrm's Avatar
Default Re: problem with ls/vtec in del sol. (JDM_Ej)
Usually people experience this problem when they have a mis-allignment of either the motor mounts or the hood. Check these things over, but if all else fails you can cut the sub-frame of the hood around where it's rubbing or you can try denting it with a hammer. Do a search, this has been covered many times. Good luck
Old Nov 9, 2004 | 05:07 PM
DC-4-Drew's Avatar
Default Re: problem with ls/vtec in del sol. (lax1185)
I had a friend who had a Civic SI hatch (87-91). His valve cover hit the hood when he shifted hard. He had a broken Motor mount and it jumped into the hood when he shifted.
Old Nov 9, 2004 | 06:06 PM
4thgen92accord's Avatar
Put some washers on the hood hinges? to raise it up a lil bit. I think Ive seen a few people do that
Old Nov 9, 2004 | 06:12 PM
MassScene's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tcr03 &raquo;</TD></TR><TR><TD CLASS="quote">yes but the ls block is taller than the gsr block. from what i hear.</TD></TR></TABLE> actually all bseries blocks come from the same casting.
Old Nov 9, 2004 | 08:53 PM
tcr03's Avatar
Default Re: problem with ls/vtec in del sol. (MassScene)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MassScene &raquo;</TD></TR><TR><TD CLASS="quote"> actually all bseries blocks come from the same casting. </TD></TR></TABLE>
sorry but i think your wrong on this one.
Old Nov 9, 2004 | 10:12 PM
dantastic's Avatar
b18b, b18c, b18c-r, b20, b16b all have the same block height. the b16a is a bit shorter (by a few mm).
Old Nov 9, 2004 | 10:51 PM
untitledsn41's Avatar
Default Re: problem with ls/vtec in del sol. (dantastic)
i have this problem with my B18C in my EH2. it was hitting in 2 differnt places(i hammerd up one of the hood supports in one of the spots which solved one of them)
but my front right corner of the valve cover smacks against the hood when slamming gears and there is a big nasty paint crack/dent of where the corner of my valve cover smacks.
ive noticed other people having this problem too
curtparia93
Apr 27, 2017 09:15 AM
RainbowHiker
12
Aug 13, 2016 02:15 PM
grape1161
Aug 4, 2011 05:45 AM
Teh_Oven
Apr 17, 2005 05:43 AM
bubbajim
14
Mar 13, 2003 10:39 PM
