NEED HELP car won't start
Old Nov 8, 2004 | 06:30 PM
HOND PWR's Avatar
Default NEED HELP car won't start
I was driving normally on the interstate, and the motor just shut off. Tried to restart it...motor turns over but no start.
Sounds to beback firing through the throttle body
Any suggestions?
Set-up is 89 CRX hf with 2001 ITR motor with OBD 0 b16 wiring
Old Nov 8, 2004 | 06:41 PM
krazie1's Avatar
BANNED
Default Re: NEED HELP car won't start (HOND PWR)
sounds like a bad ECU or spark to me
had the same problem in my 89 civic w/swapped motor
why did u use OBD0 wiring in a 01 ITR???
kinda of dumb I would of at least used OBD1 to get the max of power out of that bad boy
Old Nov 8, 2004 | 06:57 PM
HOND PWR's Avatar
Default Re: NEED HELP car won't start (krazie1)
I bought the car really cheap the way it is. I was planning on changing over to obd1 with hondata before spring time.
I'll check for spark in the morning. Any tips on checking for a bad ECU? with out swaping ecu's.
Old Nov 8, 2004 | 08:47 PM
krazie1's Avatar
BANNED
only way I can tell u w/o swapping is when u try to crank it
the check light will stay on and won't flash or the ecu if u using obd0 ecu the led on there won't flash to give u a code
that is a simple way to find out
Old Nov 15, 2004 | 08:37 AM
HOND PWR's Avatar
Finally found the problem...Bad bearing on the distriubuter. Looks like the shaft got hot (from the bad bearing??) and melted the rotor button on the shaft.
Guess this will be a good time to upgrade to OBD1
Might post some pics later.
crookson speed
Feb 19, 2014 01:32 PM
hamst3r3x
Nov 5, 2007 09:45 AM
EFKevin
Jul 22, 2007 07:45 PM
StewdaddySiRII
Oct 27, 2004 03:18 PM
Hybrid Invasion
14
Apr 23, 2003 07:33 AM
