fast idle valve need some help
whats up guys. trying to help a friend out. Hes got a JDM obd0 B16a in a rex and needs a new fast idle valve. Im not too experienced with these older jdm motors so what U.S. car does he need to get the valve from? Will any obd1 valve work, or is there something special for obd0? I think the motor originally came out of an old school jdm integra. any help is greatly appreciated. thanks guys, josh
instead of having the coolant line that goes from the intake manifold to the throttle body and then to the iacv . just run a hose from the intake manifold directly to the iacv in the back.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fobtions »</TD></TR><TR><TD CLASS="quote">instead of having the coolant line that goes from the intake manifold to the throttle body and then to the iacv . just run a hose from the intake manifold directly to the iacv in the back.</TD></TR></TABLE>
You can do this...but then youll have to hold the gas until its warm. I have to do this because the Skunk2 IM doesnt have a place for one.
when doing the coolant bypass mod could you use those plastic vacuum hose connectors?
i dont think they would melt but wanna know what kind of hose connectors to use if you dont recommend them...
http://www.partsamerica.com/Pa...4016A
i have these somewhere in my garage...
Modified by 88crx-si at 11:52 PM 11/8/2004
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fobtions »</TD></TR><TR><TD CLASS="quote">whut do u mean? its on the throttle body?
some throttle bodies have a different style, maybe thats whut u meant</TD></TR></TABLE>
hey thats my TB
here you go man, FIX the problem dont bypass it
https://honda-tech.com/zerothread?id=699787
hey thats my TB
del sol b18c
Sep 10, 2007 11:43 PM
