question about my completed DOHC ZC swap
Old Nov 8, 2004 | 03:40 PM
mengy007's Avatar
Default question about my completed DOHC ZC swap
I just swaped in an OBD1 DOHC ZC into my 93 hatch. I'm using a chipped p28 ecu w/ VAFC attached.
I'm also using my DX header.
My question is, power seems to drop from 3krpm - 4.5krpm so it feels really strong from 2k - 3k but takes forever to get to 4.5k then it picks up a lot... I lower the Air correction into the negatives on my VAFC and it seems to run a little better but still lags from 3k - 4.5k.. anyone know what's wrong?
Old Nov 8, 2004 | 03:42 PM
sheissrx's Avatar
Default Re: question about my completed DOHC ZC swap (mengy007)
you gotta set the vtec to a lower rpm
Old Nov 8, 2004 | 04:09 PM
mengy007's Avatar
Default Re: question about my completed DOHC ZC swap (sheissrx)
LOL thanks for the laugh, incase you were serious, this is a non-vtec DOHC ZC engine so i set the vtec to the highest rpm so it won't (try to) engage.
is distributor timing supposed to be off 19 degrees BTDC?
what if i've advanced the distributor a lot but it's still just straight on. Should I check timing with cams and crank?
Old Nov 8, 2004 | 04:26 PM
SETI20's Avatar
I'm not sure this is going to work... does the obd1 B series dizzy even bolt up?
Old Nov 8, 2004 | 04:30 PM
drdisco69's Avatar
Default Re: (SETI20)
If you're off a tooth on a cam gear, you probably won't be able to bring it into time at all with the distributor.
Old Nov 8, 2004 | 06:14 PM
mengy007's Avatar
well it came with a distributor and all the plugs were OBD1 so i guess it's for real.... when i rotate distro all the way towards firewall, it seems like the intake cam is off by one tooth, i'll check it again tomorrow, thanks for all your help.
Old Nov 8, 2004 | 06:18 PM
mike_belben@yahoo.com's Avatar
From: not riding any bandwagons in, massachusetts, usa
by "dx header", do you mean the HF and STD style with the cat upfront?
if so, its horribly restrictive and reversion is going to be giving you headaches, funky bogs, crummy mileage, stutteriness. does the car feel like it decelerates rapidly when you let off the gas?
atleast get a stock d15b2 or a6 manifold if you are currently running the turd.
Old Nov 8, 2004 | 06:37 PM
jlicrx's Avatar
Default Re: (mike_belben@yahoo.com)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike_belben@yahoo.com &raquo;</TD></TR><TR><TD CLASS="quote">by "dx header", do you mean the HF and STD style with the cat upfront?
atleast get a stock d15b2 or a6 manifold if you are currently running the turd. </TD></TR></TABLE>
he said his car is 93 hatch
Old Nov 8, 2004 | 07:56 PM
mengy007's Avatar
Default Re: (jlicrx)
Sorry for the mis-information. the dx header is from my 93 dx hatch the 4-1 one. I'm working on getting an after market header 4-2-1 design then gut out my cat or get a hi-flow cat. I already have 2.5" piping to the axel back.
I was told that the people in this form would know more about ZCs so this is why I posted in here instead of in the EG+ forums.
If my intake cam was off by one tooth, would it cause this sort of behavor?
1-3k power, 3k-5k no power, 5k - 7k power
Old Nov 9, 2004 | 07:18 AM
mengy007's Avatar
Default Re: (mengy007)
seems to be running a little better today... Can timing being off one tooth on one cam produce this sort of behavor?
Old Nov 9, 2004 | 01:06 PM
mengy007's Avatar
UPDATE: turns out the intake cam was off by 1 tooth, fixed it, runs strong now.
freshly boosted DOHC ZC
Jan 12, 2007 11:50 AM
fujiwara takumi
Dec 30, 2005 01:33 PM
BoostdRex
16
Nov 26, 2005 11:39 AM
gutted-dx
May 15, 2005 04:42 PM
Kilohead36
Sep 25, 2003 08:11 AM
