Help on 93 Civic EX Coupe motor swap
Old Nov 8, 2004 | 02:48 PM
teamkawy55's Avatar
Default Help on 93 Civic EX Coupe motor swap
Hey, like it says I have a 1993 Civic Coupe ex, and Im swapping in a b16 head with b18 LS block and tranny...I got the axels with the motor, linkage, and wiring harness, I have the p28 ecu in my car already, will I need to buy mounts, or can I use the LS motor mounts that came with the motor? Any tips, help or advice period I would appreciate, thank you...
ps...my car is set up for hydro. clutch and the LS tranny is cable, I got the cable clutch line, the clutch pedal and all the setup with the swap, can I just convert my car back to cable clutch?
Old Nov 8, 2004 | 04:22 PM
teamkawy55's Avatar
Default Re: Help on 93 Civic EX Coupe motor swap (teamkawy55)
I know my motor mounts wont line up with his, but will his mounts line up with my motor mount brackets? or do I need the whole kit? I hope not
4drDA
Sep 3, 2005 02:55 PM
B16Civic93
Nov 19, 2004 10:36 PM
LSturboEX
Jul 7, 2003 09:37 PM
