Why won't it pass smog...
Old Nov 8, 2004 | 02:01 PM
Justin1933's Avatar
Default Why won't it pass smog...
I am trying to get my ITR to pass smog, but running into a few issues. Here is the report from the smog station:
Here is a list of mods. What should I do to insure that it will pass smog?
4-1 DC Header (Non JDM)
DC SS Cat-Back Exhaust
DC CAI
Apex'i VAFC (I just reset this back to the factory settings. This was done after the smog check)
Vortec Fuel Pressure Regulator
Also, I ran the car without a cat for a while...Would I need to change out the oxygen sensor?
Old Nov 8, 2004 | 04:27 PM
hondaguyef's Avatar
Default Re: Why won't it pass smog... (Justin1933)
Go and get it tested w/ the VAFC at the factory settings. That kind of looks like a cold Catalytic converter to me.
Phil
Old Nov 8, 2004 | 05:16 PM
v4lu3s's Avatar
RTFM
and make sure that fuel pressure is at STOCK pressure...
Old Nov 8, 2004 | 06:41 PM
eda6's Avatar
Default Re: (v4lu3s)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v4lu3s &raquo;</TD></TR><TR><TD CLASS="quote">and make sure that fuel pressure is at STOCK pressure...</TD></TR></TABLE>
Also use the stock ecu.
Old Nov 8, 2004 | 10:04 PM
Propulsion's Avatar
Default Re: (eda6)
yeah, set the VAFC back,
usually high HC means running rich, high NOS means running hot/lean, and if one goes up, the other goes down. I would change the computer back to stock settings and see what that does.
Old Nov 9, 2004 | 07:10 AM
staticrex's Avatar
Default Re: (SilverCIVIC96)
Also make sure you drive the car for at least 20 minutes before getting the test done, you need to make sure the cat is doing its job and it needs to be hot. Everytime I ever failed a smog was because I drove it right around the corner never let it warm up.
MestizoRacer310
Feb 8, 2005 10:26 PM
Justin1933
Nov 8, 2004 01:34 PM
Slava.
11
Sep 21, 2004 10:12 AM
tyflip2
11
Dec 3, 2003 05:08 PM
JDMRob
14
Sep 15, 2003 12:23 AM
