Help with d16y7 swap!
Old Nov 8, 2004 | 12:38 PM
blackdc's Avatar
Default Help with d16y7 swap!
Hey, Im swapping a d16y7 long block into my 88 dx. Although, im not sure what this plug is for:
Old Nov 8, 2004 | 01:11 PM
onePOINTsix's Avatar
Default Re: Help with d16y7 swap! (blackdc)
the crank position sensor (i think thats what it's called) on OBD2 motors is there but in your car it's in your dizzy, so you'll have no problems without that wire hooked up
Old Nov 8, 2004 | 06:23 PM
CRX_Control's Avatar
Default Re: Help with d16y7 swap! (onePOINTsix)
hope your doing a mfpi swap with that too.
Old Nov 8, 2004 | 06:36 PM
blackdc's Avatar
Yep, im using a si manifold.
Old Nov 9, 2004 | 06:33 PM
StorminMatt's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by onePOINTsix &raquo;</TD></TR><TR><TD CLASS="quote">the crank position sensor (i think thats what it's called) on OBD2 motors is there but in your car it's in your dizzy, so you'll have no problems without that wire hooked up </TD></TR></TABLE>
Nope.
This plugf is for the crankshaft speed fluctuation sensor. OBDII cars use this sensor in addition to the crankshaft position sensor in the distributer rather than instead of it.
Wilfre114
Feb 9, 2023 08:07 AM
jjmcmana
Nov 1, 2008 09:02 AM
gustavito1986
Apr 6, 2008 08:52 AM
ozzyman
Feb 10, 2006 11:30 AM
KingElli
Jun 14, 2005 08:07 AM
