Throttle body question
Old Nov 8, 2004 | 12:25 PM
smash fascism's Avatar
Default Throttle body question
I took the throttle body off of my 2nd gen b16 and when I went to buy a new one, for the 99 Si it wasn't big enough to accomodate for the fast idle thermo valve. I tried a gasket from a the del sol si and it was the same gasket and it didn't cover the whole thing. Ok, now that I put it back together without a gasket whenever I drive it and then let off the gas and the butterfly closes the throttle sticks shut, because there's no gasket in there. My question is, what gasket should I try?
Old Nov 8, 2004 | 05:20 PM
Default Re: Throttle body question (smash fascism)
Anyone?
Old Nov 9, 2004 | 04:06 AM
dkhuynh's Avatar
i completely lost you in your post. what tb (throttle body) are you using right now? and what kinda im (intake manifold) are you using too. if you are using a stock b16 tb with a b16 tb, then get a b16 gasket. i have one for sell if you want. dkhuynh@gmail.com
Old Nov 9, 2004 | 04:16 AM
IN VTEC's Avatar
Use a '94 to '95 Integra GS-R gasket. It's a little bigger ID, but that won't matter. it'll have the proper holes for the FITV and IACV ports.
skiracer8148
Aug 14, 2007 09:02 PM
bootlegtrader
Feb 3, 2006 07:17 PM
4F_ Mugen CoL
Nov 10, 2005 12:53 PM
x00gsr
Jul 12, 2004 09:35 AM
