All those bored engines.....
Old Nov 8, 2004 | 12:18 PM
Cidone's Avatar
Default All those bored engines.....
Now ive been doing alot of research and have found out that after you bore the block the combusion chamber needs to be bored as well... In doing so you are lowering the CR... If you have set CR on your pistons to hold that CR you would have to get pistons with Higher CR to retain the CR you truly want... If anyone knows anything about this please help me out because im soo confused....
Modified by Cidone at 10:02 PM 11/8/2004
Old Nov 8, 2004 | 04:34 PM
notstock93's Avatar
Default Re: All those bored engines..... (Cidone)
that depends on how big of bored your talking.
if its just oversized .25-.50, then dont worry about it.
Old Nov 8, 2004 | 05:12 PM
Cidone's Avatar
Default Re: All those bored engines..... (notstock93)
im trying to do 86mm
Old Nov 8, 2004 | 05:17 PM
notstock93's Avatar
then you may need to modify the CC, but I have no further info on this process.
hoffmanb16
30
Oct 30, 2017 03:41 AM
ludeking1007
Apr 8, 2010 09:15 AM
Circusraven
Jun 22, 2008 01:40 PM
b16
Nov 4, 2003 06:17 AM
Fatty_1775
Nov 14, 2002 01:39 PM
