is the stock fuel rail threaded at the FPR?
I just got a Paxton FPR for my 92 integra - I know I need to put an AN fitting onto the fuel return line and hook that up to the new FPR. But the stock FPR is mounted directly to the fuel rail, so there is no hose I can just put a new fitting on to. How hard is it to replace the stock FPR with a hose that will hook into the new FPR.
I dunno, I do not really like those regulators (external regulators are better). If I were you, I would just get an aftermarket fuel rail that already comes tapped at the outlet side.
Dustin
Dustin
Also, can the new FPR be installed on the fuel return line after the stock FPR, leaving the stock one in place? I've seen that recommended elsewhere, and wanted to see if it would work.
Any other opinions on which route I should go? Stick with the Paxton external FPR and modify the fuel rail or get a new fuel rail. Or get a FPR that mounts directly to my fuel rail, such as the AEM.
tooquik209
Sep 11, 2012 12:40 AM
