help settle a debate: is this safe to drive with?
Old Nov 8, 2004 | 09:43 AM
Armed Ferret's Avatar
Default help settle a debate: is this safe to drive with?
Photo below--is the rotor safe to drive with the redrilled pattern as such? I say no, another says yes. thoughts?
Old Nov 8, 2004 | 09:56 AM
dfoxengr's Avatar
Default Re: help settle a debate: is this safe to drive with? (Armed Ferret)
i would say its fine, but not the best it coul be, i mean there are 2 well placed studs, and the other two, when looking at the way the force is going to be applied in a stopping situation will do their job
Old Nov 8, 2004 | 09:57 AM
SC-MK1's Avatar
I dont know, I think it should be fine. But those two holes dont look like there in the best spot.
Old Nov 8, 2004 | 10:21 AM
dfoxengr's Avatar
Default Re: (SC-MK1)
theres no other place for the holes.
Old Nov 8, 2004 | 11:05 AM
Default Re: (hybridvteceg)
my next question is this:
is there any difference between the rotor above and the fastbrakes spec-r rotors? are the fastbrakes ones ONLY a 4x100 pattern, or are they also a redrilled 5-lug? anyone who owns the fastbrakes setup care to comment?
Old Nov 8, 2004 | 11:27 AM
drdisco69's Avatar
Default Re: (Armed Ferret)
It's probably going to crack, but there's really no alternative on a stock rotor. Use it, keep an eye on it, and replace it when it breaks.
Old Nov 8, 2004 | 11:49 AM
EliteCivicX's Avatar
Default Re: (drdisco69)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drdisco69 &raquo;</TD></TR><TR><TD CLASS="quote">It's probably going to crack, but there's really no alternative on a stock rotor. Use it, keep an eye on it, and replace it when it breaks.</TD></TR></TABLE>
agreed but o well do what ya gottaaa.
Old Nov 8, 2004 | 01:11 PM
snowseeker's Avatar
Default Re: (EliteCivicX)
It doesn't look perfectly centered to me when looking at the hub in the middle.
Old Nov 8, 2004 | 01:55 PM
Default Re: (snowseeker)
camera angle was crappy. actually, come to think of it, so was the camera.
the issue is moot. the owner of the car is going to be going with the fastbrakes rotors for simplicity's sake.
Old Nov 8, 2004 | 01:58 PM
full Circling's Avatar
From: That's the wrong tone... I'm Skunk2 certified.
Are the brakes shaky when they're applied? Is the rotor centered on the hub?
Old Nov 8, 2004 | 02:44 PM
Default Re: (MugenDude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MugenDude &raquo;</TD></TR><TR><TD CLASS="quote">Are the brakes shaky when they're applied? Is the rotor centered on the hub?</TD></TR></TABLE>
again, the camera angle in that photograph was bad. since that wasn't enough the first time i said it, YES THE ROTOR IS CENTERED ON THE HUB.
i don't know if the brakes are shaky when applied. the car is on jackstands for the winter, so i guess we'll have to wait until spring to see.
Old Nov 8, 2004 | 08:51 PM
^^Sorry. I guess I was too cool to read the thread.
Old Nov 8, 2004 | 10:02 PM
Propulsion's Avatar
looks ugly, but should work fine
Old Nov 9, 2004 | 05:09 AM
iakona's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by snowseeker &raquo;</TD></TR><TR><TD CLASS="quote">It doesn't look perfectly centered to me when looking at the hub in the middle.</TD></TR></TABLE>
i agree. did you drill the holes yourself??
Old Nov 9, 2004 | 09:06 AM
Default Re: (iakona)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iakona &raquo;</TD></TR><TR><TD CLASS="quote">
i agree. did you drill the holes yourself??</TD></TR></TABLE>
FOR THE LOVE OF GOD, PLEASE READ COMPLETELY BEFORE YOU LOOK LIKE A GOOFBALL.
this is the final time i will say it: the angle of the camera (and lack of quality in the camera) used makes it appear off-center, but i assure you all, the rotor is, indeed, truly, absolutely, positively, 100%, no doubts about it, centered on the hub.
future comments regarding this issue will be severely made fun of. don't say i didn't warn you.
also, high school literacy would help 99.999% of those who've made the comments time and again realize that those rotors no longer exist. the owner is going with fastbrakes' rotors. if there's a problem with those, fastbrakes can deal with it.
Old Nov 9, 2004 | 01:13 PM
senpai's Avatar
Wow, you're so smart ... he asked if you drilled it yourself, not if it's centered or not
Old Nov 9, 2004 | 02:03 PM
Default Re: (senpai)
actually, he agreed with the quote he used regarding it not looking centered.
so you're wrong. scoff.
Old Nov 9, 2004 | 02:29 PM
snowseeker's Avatar
I don't know, if you look at the top left stud it looks alot closer to the hub hole than the bottom left or right stud.
Old Nov 9, 2004 | 03:54 PM
:squint:
seriously tho folks......this thread is like the end of a quality cigar. let it die.
Old Nov 10, 2004 | 03:34 PM
Evs-One's Avatar
Solbros Owns Me
you will be fine. Myself and SEVERAL others have used ITR rotors drilled to 4x100 with great results. But now I have moved onto running ONLY Prelude VTEC rotors...why???
same size as ITR
hubcentric on the Civic/Teg knuckles (no odd vibrations, etc)
4x100 holes fit perfectly between the 4114.3 lug holes
Plus, the rotors can be had for under 25 bucks from Napa
Old Nov 13, 2004 | 10:37 AM
Tomcat's Avatar
Those rotors are absolutely unsafe.
Old Nov 14, 2004 | 10:00 AM
colinproctor's Avatar
Default Re: (Tomcat)
doesnt look so trustworthy to me
Old Nov 14, 2004 | 01:58 PM
95ex@10's Avatar
I don,t think that is a very good idea, but could work for a short time. Why don't you just spend the $ on the right rotor.
Old Nov 14, 2004 | 04:37 PM
Default Re: help settle a debate: is this safe to drive with? (The Doctor)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The Doctor &raquo;</TD></TR><TR><TD CLASS="quote">I don,t think that is a very good idea, but could work for a short time. Why don't you just spend the $ on the right rotor.</TD></TR></TABLE>
FOR THE LOVE OF GOD, PLEASE READ PREVIOUS POSTS. I HAVE ORDERED PRELUDE VTEC ROTORS AND WILL BE USING THEM AFTER REDRILLING TO A 4X100 LUG PATTERN.
i typed that as slowly as i possibly could. is there something about this statement (second time i've said it now) that isn't able to be comprehended?
Old Nov 14, 2004 | 04:47 PM
Evs-One's Avatar
Solbros Owns Me
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Armed Ferret &raquo;</TD></TR><TR><TD CLASS="quote">
i typed that as slowly as i possibly could. is there something about this statement (second time i've said it now) that isn't able to be comprehended?</TD></TR></TABLE>
perfectly c lear....but this is Honda-Tech...people that know nothing act as if they know everything.
