Will not come out of 5th gear
Old Nov 8, 2004 | 09:29 AM
Rod.'s Avatar
Default Will not come out of 5th gear
I came around this corner with my 5th gear engaged. I tried to down shift to the other gears and it just stayed in 5th. I pulled pulled and pulled on it ...no luck. What kind of things should I be looking for in this situation?
Old Nov 8, 2004 | 10:17 AM
GrayT's Avatar
Default Re: Will not come out of 5th gear (redturbocivic)
How's your clutch fluid i.e. brake fluid?
My friends old *** accord used to do this and we just added some brake fluid and it cured it within minutes.
Old Nov 8, 2004 | 10:33 AM
PlastikOwl
Guest
Posts: n/a
Default Re: Will not come out of 5th gear (GrayT)
well..if it's in 5th gear...you should be pushing on it...not pulling
Old Nov 8, 2004 | 10:47 AM
MAV3RiCK478's Avatar
Default Re: Will not come out of 5th gear (PlastikOwl)
mine did that when i had my old clutch in it (160K oem) but never happened again after i changed my clutch.
and umm yeah its pulled since he wanted to go from 5th - 4th.
Old Nov 8, 2004 | 10:50 AM
PlastikOwl
Guest
Posts: n/a
Default Re: Will not come out of 5th gear (MAV3RiCK478)
you're right...I had a bit of a brain fart.
Now for a more useful suggestion from me, check your transmission fluid as well. Make sure there aren't any metal bits in there when you drain it.
Old Nov 8, 2004 | 11:21 AM
94gsr_vtc's Avatar
try pushing in the clutch. jk yeah what they said^^^
Old Nov 8, 2004 | 04:00 PM
Rod.'s Avatar
Default Re: Will not come out of 5th gear (94gsr_vtc)
bump.......no metal came out of with the transmission fluid.
Old Nov 11, 2004 | 09:25 AM
Rod.'s Avatar
I had plenty of tranny fluid. I have a act xtreme clutch w/ 6 puck unsprung
Andyxramirez
Mar 19, 2013 03:07 PM
gsrrican84
Apr 21, 2006 05:46 PM
cecknight
Aug 26, 2004 08:12 AM
totalfxaccord
Mar 21, 2004 12:18 PM
ebelp
Mar 6, 2002 06:41 AM
