Gas Guage does not read full when full?? Only reads 3/4 full?
Old Nov 8, 2004 | 08:48 AM
Spence's Avatar
Default Gas Guage does not read full when full?? Only reads 3/4 full?
Hey guys i when i messed with my cluster trying to get my integra cluster to fit better i messed up the gas gauge. When full it only reads 3/4 a tank there has to be a way to adjust this maybe on the back of the cluster??
Help
Spencer
Old Nov 8, 2004 | 09:51 AM
Spence's Avatar
Default Re: Gas Guage does not read full when full?? Only reads 3/4 full? (Spence)
up
Old Nov 8, 2004 | 10:00 AM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spence &raquo;</TD></TR><TR><TD CLASS="quote">there has to be a way to adjust this maybe on the back of the cluster??</TD></TR></TABLE>
Well AFAIK, there isn't.
I'm assuming it was working properly before you messed with it? If so, you'll probably need a new fuel gauge. $43 at the dealer, or $37 + shipping here (look under "combination meter components").
The gauges are very fragile pieces - you have to be gentle with them.
Old Nov 8, 2004 | 10:11 AM
Spence's Avatar
Default Re: Gas Guage does not read full when full?? Only reads 3/4 full? (Targa250R)
the gauge still works it even goes a 1/4 way past Empty so its just out of alignment i guess
Old Nov 8, 2004 | 11:21 AM
Spence's Avatar
bump it up
Old Nov 8, 2004 | 09:09 PM
Spence's Avatar
bump
Old Nov 8, 2004 | 09:16 PM
tcr03's Avatar
ok go fill up your tank and then take off the cover and move the needle to the full mark. and its all better.
Old Nov 8, 2004 | 09:23 PM
Spence's Avatar
Default Re: Gas Guage does not read full when full?? Only reads 3/4 full? (tcr03)
tried that its not that easy
Old Nov 8, 2004 | 09:27 PM
tcr03's Avatar
how did you move it in the first place.
Old Nov 8, 2004 | 09:28 PM
Spence's Avatar
not sure i knew that it woudl be easy to fix i moved it when i filled the tank and it moved right back
Old Nov 8, 2004 | 09:42 PM
tcr03's Avatar
have you ever taken the needles off, if so just take off the needle and put it back on full, but if i remember right the needles dont come off on the hondas. but its worth a try. if it doesnt work your still in the same boat.
Old Nov 8, 2004 | 10:32 PM
Spence's Avatar
naw im not going to try that ill break the needles
Old Nov 10, 2004 | 08:27 PM
Spence's Avatar
up
Old Nov 11, 2004 | 09:26 AM
Spence's Avatar
no one????
tekniq
Jan 14, 2009 08:38 PM
bigboi_626
Jun 6, 2007 10:27 PM
ek97Hatchcx
Feb 6, 2007 03:38 PM
sf@rx7
Feb 17, 2006 07:42 PM
oh-k
Sep 16, 2004 12:36 PM
