could this be a cam shaft problem?
Old Nov 8, 2004 | 05:19 AM
hazeleyes76's Avatar
Default could this be a cam shaft problem?
my prelude had a rusted away ring on the A pipe before the cat. which kind of always made my car shake n run like crap, so i was used to it actin up sometimes. i was in the process of looking at exahusts and gettin all that replaced. i was drivin home last night and all of the sudden my RPMS were goin crazy, goin from 1-2 really fast. then my car started makin crazy noises every time i pressed on the gas. it sounded like my exhaust was about to fall off.i pulled into a parking lot cuz i knew it was gonna die. when i went to start it again, it would rev up to 2 and then slowly fall back down to 500 then back up to 2, like it was struggling to keep power, and then it would just fall to 0 and die. all the noise is coming from the exhaust and some rattling noise from the engine. my dad thinks it might be the cam shaft? i ahve no idea. all i know is my car was towed to some shop, and i miss her! lol. could the exhaust leak caused damage to the engine?
Old Nov 8, 2004 | 06:30 AM
SuperSlow's Avatar
Default Re: could this be a cam shaft problem? (hazeleyes76)
If you sprung a leak before the O2 sensor, that may be your culprit. Otherwise check vacuum lines on IM.
Old Nov 8, 2004 | 11:47 AM
Default Re: could this be a cam shaft problem? (SuperSlow)
thank you, the shop should be looking at it tonight.i probably wont be getting her back for a while.. lol
Old Nov 8, 2004 | 05:17 PM
luder_99's Avatar
Default cam shaft probs?
Engine is makeing a rattling noise to in the head,i think it might be the cam
ih8speedbumps
Jan 4, 2014 03:17 AM
cash2435
Aug 27, 2009 05:13 PM
devgon2
Jul 6, 2007 05:16 PM
jdmsijdm
May 3, 2004 04:01 PM
JM Performance
Jun 3, 2002 06:14 AM
