Front roll bar - how difficult to change?
Old Nov 8, 2004 | 04:10 AM
00R101's Avatar
Default Front roll bar - how difficult to change?
Anyone out there swapped out their front roll bar? How many hours? What's involved?
tia,
Alan
Old Nov 8, 2004 | 06:50 AM
JDM CTR '00's Avatar
Default Re: Front roll bar - how difficult to change? (00R101)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00R101 &raquo;</TD></TR><TR><TD CLASS="quote">Anyone out there swapped out their front roll bar? How many hours? What's involved?
tia,
Alan</TD></TR></TABLE>
Front roll bar? or sway bar?
Old Nov 8, 2004 | 06:54 AM
Drive01's Avatar
I'm assuming sway bar.
you've got to drop(lower) your cross member. And to drop you cross member, you've got to disconnect your steering column. So there would be a chance that you're steering wheel isn't straight anymore. It won't mess up your alignment, you would just have to remove and realign you steering wheel.
Old Nov 8, 2004 | 06:59 AM
Default Re: Front roll bar - how difficult to change? (Drive01)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Drive01 &raquo;</TD></TR><TR><TD CLASS="quote">I'm assuming sway bar.
you've got to drop(lower) your cross member. And to drop you cross member, you've got to disconnect your steering column. So there would be a chance that you're steering wheel isn't straight anymore. It won't mess up your alignment, you would just have to remove and realign you steering wheel. </TD></TR></TABLE>
if it is the sway bar what you just listed does not have to be done. I hope you are joking. It will take about 20 mins if you have a lift. Doing it on the floor alone about 35-40 mins. It's not that hard at all, pretty much you would have to unbolt the exhaust piping. Then you would have to drop the shift linkage. The rest is pretty much unbolt whatever is needed to take off the bar.
Old Nov 8, 2004 | 07:06 AM
Chris N's Avatar
You don't have to mess with the steering column.
It takes about twice as long as changing the rear sway bar. Easy.
Old Nov 8, 2004 | 09:23 AM
00R101's Avatar
Default Re: Front roll bar - how difficult to change? (Chris N)
Thanks for the responses.
Old Nov 8, 2004 | 09:25 AM
Old Nov 8, 2004 | 12:14 PM
Doctor CorteZ's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Drive01 &raquo;</TD></TR><TR><TD CLASS="quote">you've got to drop(lower) your cross member. </TD></TR></TABLE>
I assure you that step does not need to be done.
at the most you have to drop the cat down out of the way to twist the bar out.
Old Nov 8, 2004 | 12:50 PM
norice's Avatar
Default Re: Front roll bar - how difficult to change? (Doctor CorteZ)
You don't have to touch the cross member. Disconnecting the shift linkage and the cat are all that is required.
jplowman2005
Suspension & Brakes
Oct 31, 2008 05:09 PM
neozero999
Apr 22, 2008 04:39 PM
brian_98EK
Sep 8, 2007 12:22 PM
Ibazndude
11
Jul 20, 2007 09:12 AM
JMD
Apr 13, 2003 07:30 PM
