oil loss plz help???
Old Nov 7, 2004 | 08:19 PM
b16a27's Avatar
Default oil loss plz help???
ok i have a b16a and i got my oil changed about 1000 miles ago and i check it today i am 1 quart low ok i dont see any blue smoke or any else exhaust very clean even when reved high i didnt check in throttle body to see in there but its not leaking but here is my situation i have no 5th gear so when i travel on E-way im at 4k-5k most of time on freeway and i do some racing also can this be the problem because on e-way always at high revs plus i race or is something very wrong with my car by the way runs the same as always did really strong HELP PLZ
Old Nov 7, 2004 | 08:38 PM
skunk2eg's Avatar
Default Re: oil loss plz help??? (b16a27)
you got your oil changed? meaning u didnt do it yourself...if its a swapped car they usually go buy the oil level of the original motor, add oil if it leaks or burns it could be a number of things
Old Nov 7, 2004 | 08:49 PM
bee18's Avatar
i had an oil leak from not tightening the drain plug once, check the simple stuff like valve cover gasket
DO_ITR_YoungD_19
Honda S2000
11
Nov 24, 2008 08:38 PM
DAintegraGSR
Apr 28, 2005 08:22 PM
b16a27
Nov 7, 2004 08:26 PM
magic hat #9
Apr 21, 2004 02:24 PM
T25So
Mar 22, 2004 08:23 PM
