Car pulling to the left..cant figure it out
Old Nov 7, 2004 | 07:19 PM
Chubz's Avatar
Default Car pulling to the left..cant figure it out
It started happening after i took my car to the track. I did alot of spinning and had disgusting wheel hop. I checked the axles and there is no rips or cracks in the boot. I did notice however that my lower balljoint boot on the driver;s side was rippedwas ripped, could that be the problem, I have a new balljoint that ill be putting in tomorrow
Old Nov 7, 2004 | 08:17 PM
Ross's Avatar
25 Year Member
Community Builder
Community Influencer
Active Streak: 30 Days
Default Re: Car pulling to the left..cant figure it out (Chubzilla)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chubzilla &raquo;</TD></TR><TR><TD CLASS="quote">It started happening after i took my car to the track. I did alot of spinning and had disgusting wheel hop. I checked the axles and there is no rips or cracks in the boot. I did notice however that my lower balljoint boot on the driver;s side was rippedwas ripped, could that be the problem, I have a new balljoint that ill be putting in tomorrow</TD></TR></TABLE>
Align the car. Check tire pressures also.
That's just the simple stuff.
Old Nov 8, 2004 | 05:30 AM
Chubz's Avatar
Default Re: Car pulling to the left..cant figure it out (Ross R)
thnx Ross
Old Nov 8, 2004 | 07:15 AM
1999all_motoR_teg's Avatar
Check for play in the balljoint. remember whether or not it's leaking doesn't really matter it's if there is any play.
Old Nov 8, 2004 | 07:46 AM
mstewar's Avatar
Default Re: Car pulling to the left..cant figure it out (1999all_motoR_teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1999all_motoR_teg &raquo;</TD></TR><TR><TD CLASS="quote">Check for play in the balljoint. remember whether or not it's leaking doesn't really matter it's if there is any play.</TD></TR></TABLE>
how DO you check the play in the balljoint?
glad I saw this.. I have to replace some boots at least and was wondering how to tell if the balljoints themselves were shot..
Old Nov 8, 2004 | 07:40 PM
Default Re: Car pulling to the left..cant figure it out (mstewar)
You can use a pry bar. Rest the middle of the pry bar on the inside off the rim and the tip at the bottom of the balljoint where the cotter pin is. then pull down on the pry bar. If the balljoint even moves the slightest bit replace it as it's not supposed to move at all.
Sorry if that's not the best description that's the best I can think of without actually doing it.
Old Nov 8, 2004 | 07:41 PM
Mythias's Avatar
also a caliper could be binding...
Old Nov 9, 2004 | 12:25 PM
Chubz's Avatar
Default Re: Car pulling to the left..cant figure it out (mythias)
update:
replaced the ball joint because when we removed the lower control arm you could grab the threaded area of the joint and move it around like it was nothing, the bad bews is, its still pullung to the left im going to check the tire pressure later on, and making an appointment to have the tires balanced and an align,ent done
Old Nov 10, 2004 | 04:31 AM
You will for sure need an alignment after replacing a balljoint.
Old Nov 10, 2004 | 04:54 AM
migs's Avatar
A alignment shop should be able to tell you why the car is pulling.
Try this:
Jack up the front of the car and switch both left and right tires. Just remove the wheel from the car and change its position. NOT flip the tire.
Test drive the car and see if it pulls the other way, if it does, its the tire.
This is what you call a radial pull which sometimes is a seperated belt.
Old Nov 10, 2004 | 06:45 AM
Chubz's Avatar
Default Re: Car pulling to the left..cant figure it out (migs)
thanx, i made the appointment for it to be checked out
Old Nov 10, 2004 | 07:00 AM
cryptikman's Avatar
When you go straight, is the steering wheel straight? I remember I messed up my alignment really bad once at the track and my car at the time started pulling to the left and the steering wheel was never at the proper position when the car was going straight. But after the alignment, it was fine.
Old Nov 10, 2004 | 07:08 AM
Chubz's Avatar
Default Re: Car pulling to the left..cant figure it out (cryptikman)
no if i hold the wheel straight it goes straight, but as soon as i maybe let my hand off the wheel for a second it starts pulling to left, it never did that before, it would always stay straight, i checked my strut and its fine, ill let the shop figure out what the problem is
tommy.
May 23, 2006 08:52 AM
EKlat_9
13
Aug 8, 2004 06:29 PM
Takumi Fujiwara
Feb 25, 2004 09:17 AM
blazinb16
Apr 10, 2003 09:09 PM
B18C-RnVA
Sep 22, 2001 01:48 PM
