Help needed...Please....
Old Nov 7, 2004 | 06:47 PM
EK VTi's Avatar
Default Help needed...Please....
Sorry this might be a little off topic, not a honda... There is something wrong with my GF's car, Its a 01 VW golf, the problem is that all the electric parts on the pass. door is not working, i.e. window, power lock, mirror, except for the speaker. I have no idea what is wrong with it, so can anyone please help me please....any opinions? Thanks guys!
Old Nov 7, 2004 | 07:40 PM
eda6's Avatar
Default Re: Help needed...Please.... (EK VTi)
Sounds like those functions are locked out from the drivers side. Did you check that? Check the fuse panel. I have an 02 Jetta.
Old Nov 8, 2004 | 06:55 AM
EK VTi's Avatar
Default Re: Help needed...Please.... (eda6)
Well I played around with the bottons at the driver side door, but nothing happen, and when I use the remote to lock the car, that lock on the pass, side isn't working neither, and as for the fuse, do you have the number of what fuse I should check? Thanks for your help!!
Old Nov 8, 2004 | 02:16 PM
EK VTi's Avatar
Anyone? Please.....?
Old Nov 8, 2004 | 07:22 PM
eda6's Avatar
When you open the driver door, on the side of the dash is the fusebox. Inside the fusebox, you'll find a fuse box diagram with a symbol for each fuse. Try the ones that look like a key. There's also a few symbols that look like a book. Don't know what they go to. Check those too. Fuses 6,7,38 have the key symbol. Unsure if 01 golf and 02 jetta are similar.
Another possibility is that you have a bad circuit breaker for the passengers side window. This circuit breaker was installed to prevent the window motor from overamping when the window was frozen shut. It's supposed to be an auto reset breaker. There's another fuse panel on top of the battery. Remove cover and look for two tabs. Ckt breakers are next to fusible links they're green and white.
Let me know what you find
Modified by eda6 at 9:06 PM 11/8/2004
Old Nov 11, 2004 | 07:25 PM
EK VTi's Avatar
I played around with the fuse and checked the wiring, nothing help, so I end up took it back to the dealer, and they told me it was some bad connection or something.....I donno.... just happey that its fixed and its working now...and thanks guys for your help, thanks.
babykake91
Mar 30, 2017 02:04 AM
vtectouge
Audio / Security / Video
Jun 23, 2010 05:48 PM
SKY350
Acura TSX
Jan 19, 2010 04:44 PM
alperin
Oct 29, 2007 06:40 PM
slo95cx
Aug 7, 2004 08:47 AM
