How to clean 97 EK headlights?
Old Nov 7, 2004 | 05:58 PM
Brian Hinson's Avatar
Default How to clean 97 EK headlights?
Hey guys,
Ever since I got my EK, (its a 97) the headlights have been faded looking and yellow-ish. I always thought this skank stuff was on the inside of the headlight, so I took them apart today with the intent of killing two birds with one stone; painting them, and cleaning them. Well the faded-ness is on the outsideand it wont come off, how do I get rid of it?
TIA, I searched but it was down, surely im not the only person with this problem.
Old Nov 7, 2004 | 05:59 PM
Ricey McRicerton's Avatar
Default Re: How to clean 97 EK headlights? (BrianHinson)
Plastic polish and patience.
SOHC4life 96's Avatar
Go do a search about this in the appearance and cosmetic forum there are many useful threads about how to clean them and get them looking brand new.
Edit: Damn the search function is still down. There are lots of products out there to tackle this task. Ricey's suggestion, I know either mother's or mequires sells similar stuff. Go to any auto parts store and ask them. This does take some elbow grease though.
Old Nov 7, 2004 | 06:04 PM
distortedfuture's Avatar
Default Re: How to clean 97 EK headlights? (DOHC4life)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DOHC4life &raquo;</TD></TR><TR><TD CLASS="quote">Go do a search about this in the appearance and cosmetic forum there are many useful threads about how to clean them and get them looking brand new.
Edit: Damn the search function is still down. There are lots of products out there to tackle this task. Ricey's suggestion, I know either mother's or mequires sells similar stuff. Go to any auto parts store and ask them. This does take some elbow grease though. </TD></TR></TABLE>
Old Nov 7, 2004 | 06:10 PM
TurboTagTeam's Avatar
I have the same problem. I looked everywere and couldnt find any plastic polish. i was told to use rubbing compound but it didint work at all. Im stumped.
Old Nov 7, 2004 | 06:13 PM
B16aDasher's Avatar
I used metal polish, then finshed off with plastic polish when i did mine. Came out sweet!!
Old Nov 7, 2004 | 06:26 PM
Richard Noggin's Avatar
From: Good luck to this industry, you're gonna need it.
Default Re: How to clean 97 EK headlights? (TurboTagTeam)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboTagTeam &raquo;</TD></TR><TR><TD CLASS="quote">I have the same problem. I looked everywere and couldnt find any plastic polish. i was told to use rubbing compound but it didint work at all. Im stumped. </TD></TR></TABLE>
I think Meguiars makes something called Plasticx or something to that effect. Check out http://www.meguiars.com.
I used that on my headlights, unforunately mine were bad enough that it KINDA works. I have seen with my own eyes this stuff work like a DREAM.
-Chris
Old Nov 7, 2004 | 06:51 PM
Dropped90Integra's Avatar
Default Re: How to clean 97 EK headlights? (THEHARDWAYEK)
Use Mothers mag & aluminum polish, stuff works great, just take your time and use your elbows
Old Nov 7, 2004 | 06:54 PM
The Mista Mike's Avatar
Default Re: How to clean 97 EK headlights? (IntegraB18LS)
Yeah, I've always heard useing a good metal polish. I used some Blue Magic on mine after I wetsanded with Goo Gone. I had to get some clear coat overspray off of em, though.
Old Nov 7, 2004 | 06:55 PM
mulletov's Avatar
Heres a nice writeup.
https://honda-tech.com/zero...age=1
Old Nov 7, 2004 | 07:00 PM
bluebird's Avatar
Default Re: How to clean 97 EK headlights? (mulletov)
well that is a nice write up but I use this stuff I purchased at the 99cents store.. Its a yellow bottle that says "LA's Awesome cleaner... Just spray and watch the yellow and cloudiness go away!!
Old Nov 7, 2004 | 07:12 PM
mulletov's Avatar
I tried stuff in a bottle like that PlastX. Looks good till u wipe it off and the scratches reappear. I'll prob do the sandpaper method one of these days.
Old Nov 7, 2004 | 07:44 PM
IWearMyKswiss's Avatar
New User
Default Re: (mulletov)
i wetsand with fine grit finishing sand paper,..then i buff with 3M compound and then use a nice polish
Old Nov 7, 2004 | 08:35 PM
JDMEk9Gsr's Avatar
Meatl Polish is your answer did it to mine and came out sweet.!!
Old Nov 7, 2004 | 08:55 PM
jdmek910's Avatar
Default Re: How to clean 97 EK headlights? (JDMEk9Gsr)
i was reading on another site about wet sanding them and clear coating them?
has anyone tried this?
Old Nov 7, 2004 | 08:58 PM
=GAME='s Avatar
Default Re: How to clean 97 EK headlights? (jdmek910)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmek910 &raquo;</TD></TR><TR><TD CLASS="quote">i was reading on another site about wet sanding them and clear coating them?
has anyone tried this?</TD></TR></TABLE>
i did this to my tail lights and cluster cover. wetsand with 1000+ grits then lay a coat or 2 of car clear. came out clean. im not sure about the rattle can clear thought.
Old Nov 7, 2004 | 09:44 PM
New User
Default Re: How to clean 97 EK headlights? ([G][A][M][E])
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by [G &raquo;</TD></TR><TR><TD CLASS="quote">[A][M][E]]
i did this to my tail lights and cluster cover. wetsand with 1000+ grits then lay a coat or 2 of car clear. came out clean. im not sure about the rattle can clear thought.</TD></TR></TABLE>
metal can clear can be made to look good also,..all you have to do is sand down the lens,..spray on a few coats of clear,..wet sand the clear coats,..then buff out the lens
Old Nov 7, 2004 | 10:10 PM
kyosoeg6's Avatar
Default Re: How to clean 97 EK headlights? (2.0 EK)
i took off my girls headligts from the car and sprayed carb cleaner on them. took about half a can per light and usee the yellow **** fall right off. then wipe them off and let dry, then get some 99c spray can clear from walmart and spray it on there. let dry for about 15-20minutes and they look 1000times better. i will post pics and maybe do a small write up later this week.
Old Nov 7, 2004 | 11:18 PM
OneFire's Avatar
Default Re: How to clean 97 EK headlights? (kyosoeg6)
Hey, let me try to help you out.
If your headlights aren't clean after reading this thread and trying the things out, it's time for new headlights.
I've done every possible DIY to get out the fog. Wetsanding, polish, waxing and etc. Only one of my headlights came out looking new. But the other one stayed foggy, it helped a little but bahh, time for some new headlights
yoshi_1r's Avatar
yeah,,i use blue magic mag polish, takes time and sum hard rubbing, but worth it
Old Nov 8, 2004 | 07:47 AM
MrBui's Avatar
Default Re: (yoshi_1r)
i sell some stuff at work that has a sealer that seals it up after you wet sand it.
http://brightsolutionsinc.com/
works pretty good goes for about 30 bucks
Old Nov 10, 2004 | 06:56 PM
darkd1gt's Avatar
quit goin to concerts. and get some cool head light black out covers lmfao
Old Nov 11, 2004 | 12:37 AM
colinproctor's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BrianHinson &raquo;</TD></TR><TR><TD CLASS="quote">Ever since I got my EK, (its a 97) the headlights have been faded looking and yellow-ish. I always thought this skank stuff was on the inside of the headlight, so I took them apart today with the intent of killing two birds with one stone; painting them, and cleaning them. Well the faded-ness is on the outsideand it wont come off, how do I get rid of it?</TD></TR></TABLE>
do the 99-00 front end swap
Old Dec 21, 2004 | 09:11 PM
Civic4less's Avatar
Default Re: How to clean 97 EK headlights? (FdOoUoRr)
awesome... i'm doing this when my intake comes in. (So i can install the intake, paint the headlights, and clean them all at the same time :-D)
Old Dec 27, 2004 | 02:43 AM
DAP97SI's Avatar
https://honda-tech.com/zerothread?id=813209
Sebbe
Oct 26, 2010 09:32 AM
DRAGWORKS
Jun 17, 2007 01:31 PM
turnsignalandy
Sep 12, 2006 12:28 AM
imissmyfc3s
May 8, 2005 03:59 PM
marc.ejay-twenty
Aug 8, 2003 07:21 PM
