Heater not working :( IM FREEZING!
Old Nov 7, 2004 | 05:28 PM
lYellowDragonl's Avatar
Default Heater not working :( IM FREEZING!
can someone show me the wirings for the heater? cause my heater just stoped working but when i remote start it and put the key it turns on but when i step on the break(disables remote start) it turns off i have a CRX with a B16a the controls work cause when i remotestart with the key in i can turn it off and on with the controls any ideas?
Old Nov 7, 2004 | 06:20 PM
Default Re: Heater not working :( IM FREEZING! (lYellowDragonl)
no help help?
Old Nov 7, 2004 | 06:26 PM
91civicEX's Avatar
prolly wired up the alarm wrong. check the blue wire at the ign switch i think. it controls the fan.
Old Nov 7, 2004 | 06:51 PM
do you know where i can tap it soo it can go on? any wiring pics?
Old Nov 7, 2004 | 07:49 PM
GeorgeLouis1618's Avatar
Damn, I feel your pain. I'm just trying to replace my damn heater fan for my wagon. Pain in the ***. Good thing I'm not driving it right now. Who installed your remote start? I'd start callin their *** (assuming it worked before it was installed)
Old Nov 7, 2004 | 07:54 PM
vitrox's Avatar
sounds like they t-tapped your accessory wire and it broke the part going to the ignition while the part after the ignition is still connected to the autostart.. you should take it back and have them redo the ignition harness wires.
if you care to do it yourself, if you pull the fuse panel cover off the ignition wires are right there. the large yellow wire is the accessory wire, and the black yellow is the ignition wire. check both of those, one of them turns on the heater fan, its most likely the yellow one.
if you have a probe test them both.
Old Nov 8, 2004 | 02:44 PM
i mean it worked before for like more then 5 months and suddenly it stops? yea they installed it for me ill probbly bring it back to them but if i can fix it ... it would save me a bunch of time instead of letting them hold on my car which is the only car i have :\
Old Nov 8, 2004 | 05:41 PM
no one got the wiring diagram(sp) ?
Old Nov 8, 2004 | 08:43 PM
higgunscrx's Avatar
go here http://www.bulldogsecurity.com...1.htm
all the wires are identified for crx's
Old Nov 8, 2004 | 08:56 PM
krazie1's Avatar
BANNED
Default Re: (higgunscrx)
there u go great help always bro
and well wish I could be just like this and just fix mine but I can't I removed it all for less weight wow what a dumbass I am freezing now every morning
until summer starts again which should be in two months here in so cal
LoL
Old Nov 9, 2004 | 05:37 PM
thanks im going to do this this weekend cause i need my HEAT!
flash0124
10
Oct 6, 2012 10:56 AM
joeybl1987
Nov 8, 2010 03:47 AM
Hanmin
Audio / Security / Video
12
Sep 30, 2010 07:20 PM
kleen98accord
15
Aug 25, 2008 12:18 PM
coryblsmn
Mar 27, 2005 06:33 AM
