stage 3 skunk cams w/boost
i am doing a turbo setup on a 8:5:1 2liter bottom end with a gsr head i had a 2 stage nitrous setup but had fuelpump failure after 1 year and the motor broke. so now i am doing a turbo setup and wondering if anyone here has used large cams on a turbo setup. i not i will get a set of ctr cams. i am going to use a sc63 or a gt35r turbo with this setup
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bign2odaddy »</TD></TR><TR><TD CLASS="quote">i am doing a turbo setup on a 8:5:1 2liter bottom end with a gsr head i had a 2 stage nitrous setup but had fuelpump failure after 1 year and the motor broke. so now i am doing a turbo setup and wondering if anyone here has used large cams on a turbo setup. i not i will get a set of ctr cams. i am going to use a sc63 or a gt35r turbo with this setup</TD></TR></TABLE>
They're not going to be ideal, but you can use your cam gears to dial out a LOT of the overlap. Keep in mind that with lots of duration on cams like that, provided you have proper headwork, your motor is going to keep making power for a long time, so make sure all your components are up to snuff.
all_motoref9
Apr 16, 2004 09:55 AM
GReddySetGO
Nov 16, 2001 07:41 PM
