why is there a spark near battery when i start car?
Old Nov 7, 2004 | 03:40 PM
oh-k's Avatar
Default why is there a spark near battery when i start car?
this has happened more than once. i start my car and there are some sparks around my battery. is this normal?
Old Nov 7, 2004 | 05:36 PM
Keno20's Avatar
Default Re: why is there a spark near battery when i start car? (oh-k)
make sure your leads arent touching or close to anything that would make them arc or short circuit
Old Nov 7, 2004 | 06:16 PM
sabotage7's Avatar
thats not good! i hope you dont develop a fuel leak!.........do what Keno said....also check your grounds and make sure your red cover thingy is over your positive terminal bc maybe its arcing there.
good luck!
Old Nov 7, 2004 | 06:32 PM
baddog's Avatar
try getting a lower profile battery. or check for obstructions under your battery that will not let it seat in the battery box. that could possably cause it to arc. when you turn your motor over it torques causing your battery to vibrate and arc on the hoodd? is it straped down??
Old Nov 7, 2004 | 06:43 PM
oh-k's Avatar
Default Re: why is there a spark near battery when i start car? (baddog)
the battery is strapped down. when you say arc, do you mean if the battery is slanted, such as not being leveled?
Old Nov 7, 2004 | 06:52 PM
baddog's Avatar
just make sure it does not hit the hood .....
Old Nov 7, 2004 | 08:23 PM
JustinG60's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oh-k &raquo;</TD></TR><TR><TD CLASS="quote">the battery is strapped down. when you say arc, do you mean if the battery is slanted, such as not being leveled?</TD></TR></TABLE>
arc would be there actually being a spark emitted from the terminals... another use for the term would be my plug wires are arching. i.e. emitting the spark from the wire onto another item in the engine.(very common for 8v VW's from the wire to the cyl head. this is sometimes cause of the metal protector and the wires being over $100 just for cheap OEM ones so no one ever wants to replace them)
thought i'd help you understand what they're talking about
hatch_
Aug 8, 2008 12:48 PM
tigueremalo
May 23, 2006 10:55 AM
speedracer33
May 2, 2005 08:57 AM
vizsual00
Aug 11, 2003 11:48 AM
WTypeRogerX
Mar 18, 2003 01:11 AM
