Check engine codes, help!
ok i have 92 hatch with a b16 2nd gen swap, the car is throwing a few codes, first one is a code 3(map sensor), also a code 7(TPS), a code 8(top dead center sensor) and a code 21 which is vtec solenoid valve and also a code 41(oxygen sensor heater), if anyone can help that would be kool, thanks alot
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsr2envy »</TD></TR><TR><TD CLASS="quote">ok i have 92 hatch with a b16 2nd gen swap, the car is throwing a few codes, first one is a code 3(map sensor), also a code 7(TPS), a code 8(top dead center sensor) and a code 21 which is vtec solenoid valve and also a code 41(oxygen sensor heater), if anyone can help that would be kool, thanks alot</TD></TR></TABLE>
code 3, 7 = swap the map and tps plug and see if the those code will clear.
code 21= check to see the wire you got it plug in at the sensor and ecu properly.
code 41 = bad o2 sensor, not plug in.
code 8 = <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slambedcivic »</TD></TR><TR><TD CLASS="quote">youll need a new dizzy for that code. its a lil piece that gets broken in the dizzy itself</TD></TR></TABLE>
foesicks
Jun 4, 2003 09:47 AM
