stock sleeves w. forged pistons
Old Nov 7, 2004 | 02:11 PM
turbo89civicb18hatch's Avatar
Default stock sleeves w. forged pistons
i have an ls block that i am building w. pstons rods block guard and head studs. i have heard that if u run stock sleeves w. forged pistons u need to bore the sleeves to 81.5mm, is this true?
Old Nov 7, 2004 | 02:15 PM
slambedcivic's Avatar
Default Re: stock sleeves w. forged pistons (turbo89civicb18hatch)
it all depends on the size of the pistons.
Old Nov 7, 2004 | 02:32 PM
Default Re: stock sleeves w. forged pistons (slambedcivic)
is it ok to run 81mm pistons w. 81mm stock sleeves
Old Nov 7, 2004 | 02:48 PM
B18 CYA's Avatar
yes it is
Old Nov 8, 2004 | 04:08 PM
ExospeedAMcrx's Avatar
the reason for boring to 81.5mm is because.
When doing a rebuild, the next step up from stock for hone/bore is 81.5mm
You should bore to 81.5mm so the proper clearances can be measured to the piston spec. With a proper hone/bore your rings will seat well and the pistons will fit in the cylinders properly.
Old Nov 8, 2004 | 04:42 PM
eddyboy's Avatar
People usually go .20 over to make sure the bore of the cylinder is true. When I did my build I bought stock bore pistons size. It ended up my cylinder wall was just a tad bit out of spec so I had to go through the hassle of selling the my stock bore pistons for some .20 overs.
GL
slammedef06
Apr 8, 2013 09:16 PM
sportyaccordy
Mar 11, 2006 05:55 PM
Black R
Mar 17, 2005 07:22 PM
swlabhot
May 20, 2004 01:44 PM
MisterB
Jan 15, 2002 11:26 AM
